Dave Ward's 1/35 ICM Ford V3000
    I picked this out of the stash,[ATTACH]307949[/ATTACH]
    Thought the box was a little heavy, and found the contents of this as well........................
    [ATTACH]307950[/ATTACH]
    The Revell reboxing of the standard ICM wheeled V3000!. You can, in fact make the wheeled version from the ICM Maultier box, 4 sprues being the same as the all wheeler. One additional sprue for the Maultier, with suspension, and link and length tracks.
    Revell seem to take a batch of a ICM model, and release it for a limited period, often at a good price - which is probably where mine came from!
    Now, I can make the All Wheeler, or the Maultier ( NO, not both! ), but can't decide which - preferences anyone?
    • 18892
    Hi Dave
    Go for the wheeler this time...it will make a change from the ubiquitous Blitz....
    Tim
      • 15669
      Hi Dave
      My vote would be for the half track version. Bit of a cruel vote 'cause it means fiddly tracks. Strange that so many half tracks were used during the war and yet there do not seem to be any current half tracks.
        The Blitz was based on the Opel truck, this Maultier is based on the Ford.
        The half track? it's neither one thing or another, not as good on roads as an all wheeler, and not as good as a fully tracked vehicle X-country. It was simpler to build, under wartime conditions, but removing that factor, lost favour. Interesting that the Russians never went for half tracks in any major way, you'd think with all that snow a half track could be useful
          • 18892
          Am I right in thinking a lot of these were fitted with Bren carrier tracks and wheels captured from the BEF? They certainly look like the same running gear, and it would be a useful recycling opportunity.
          Tim
            Tim,
            The smaller maultiers used PzKpfw I tracks, - the larger maultiers used the Pzkpfw II tracks as seen in the Zvezda L4500R Maultier ( Incidentally 'maultier' means mule for non German speakers ).
            [ATTACH]307967[/ATTACH]
            I have one of those in the stash as well!
            The Pzkpfw I had very similar running gear to the Universal Carrier - Horstmann suspension, from the Vickers light tanks.
            • minitnkr
              Charter Rabble member
              • 7520
              • Dayton, OH USA
              W/no powered front axle the Ford had little off road capability, so for military use the halftrack solution made sense. I believe it also was more reliable with the load spread out over the tracks' suspension. Maultier gets my vote. PaulE
                I knew I had a box of boxes, barrels etc, after a hunt, I found it.....................[ATTACH]308035[/ATTACH]
                Most of it Value Gear - I think I can make up one truck load!
                  Because they add a lot of complexity (and thus maintenance and repairs) as well as increased weight (and thus fuel consumption) for little practical gain. Cross-country mobility is better than of a wheeled vehicle, true, but not as good as of a full-tracked vehicle. In practice there arenโ€™t that many situations where a half-track has a real advantage over an all-wheel-drive, which is both cheaper and easier to maintain, especially given advances in all-wheel-drive technology since the Second World War.
                    • 22770
                    Nice Dave I quite like the wheeled one.
                    • JR
                      • May 2015
                      • 18273
                      Well you know my feelings on wheeled things:sad:, Dave
                      so I'd like to see how it;'s done :smiling4:
                      John .
                      • scottie3158
                        • 14201
                        • Holbeach
                        Dave,
                        I built the maultier a while ago it builds up to a nice kit. It will be good to see your take on it.
                          Since I have both the Maultier and the wheeled version in the box, I'm going to do the wheeled version now, and the Maultier at a later date.
                          This is the Revell reboxing - plastic as the ICM, but with different decals & instructions.
                          [ATTACH]308930[/ATTACH][ATTACH]308928[/ATTACH][ATTACH]308927[/ATTACH][ATTACH]308926[/ATTACH][ATTACH]308931[/ATTACH]
                          No slide moulding - all old school. Note the chassis & truckbed rails form the outside of the sprue - top sprue shot
                          Next, a few detail shots.......................
                            The wheels are all plastic - I like this better - easier to paint, and not as heavy![ATTACH]308936[/ATTACH][ATTACH]308937[/ATTACH]
                            There is a complete engine, but as I'm doing this loaded, and a driver, the bonnet will be shut. Only assembly of the engine will be for mounting other parts - ie exhaust manifold etc. There isn't any provision for showing it open, anyway.
                            [ATTACH]308932[/ATTACH]
                            Some bits will need a fair bit of preparation, and some care in removing from the sprue.
                            [ATTACH]308935[/ATTACH][ATTACH]308933[/ATTACH]
                            The mouldings are crisp & well defined, without any flash the radiator cowl is nice..
                            [ATTACH]308934[/ATTACH]
                            The instructions follow the same sequence as the ICM versions. Having made quite a few ICM trucks, I know that they like to complete whole assemblies in one step - this means that often fragile bits can get broken off on further assembly, or they get seriously in the way of handling, so I will be deviating from the instruction sequences.
                            The chassis is 'flat packed', separate side and cross pieces forming a ladder rail. Getting this square is top priority, if you want to have all the wheels on the ground!
                            New blades in my scalpels, plastic will be cut and fitted shortly
                            • JR
                              • May 2015
                              • 18273
                              Oh dear I feel sick looking at those sprues.
                              John .
