Peerless Max Command Truck
  • grumpa
    • Jan 2015
    • 6142
    #16
    Seems a nice enough kit, and a bit unique....I like :thumb2:
    • scottie3158
      • 14221
      • Holbeach
      #17
      Andy,
      This is the sort of old kit I love a blank canvas to tweak. Bit of as bummer about the chassis how are you going to repair this?
        Chassis is glued back together, when the body goes on this should reinforce it, hopefully!
        • JR
          • May 2015
          • 18273
          #19
          I knew Simon would have one ! :smiling2:
          Andy.
          Well done on the repair, I shall draw up a seat.
          John.
            Coming together now. Drive shaft too long, made adjustment.[ATTACH]320487[/ATTACH]
            • JR
              • May 2015
              • 18273
              #21
              Andy .
              At this point I normally set fire to it ! when things just don't fit.
              John .
              • Steve Jones
                • 6615
                #22
                Well done Andy. Looks like you are beating this one into submission
                  Hi all, sorry not been around for a bit. Gave the model a light dusting and started to put together. The chassis does not fit the nodes on the base, so have lined it central as best fit. Moving a long slowly then...[ATTACH]321737[/ATTACH]
                    • 15745
                    Hi Andy
                    Missed the start of this - sorry.
                    Looks to be quite a challenge although your progress to date seems to have solved the problems. Interesting to see the finished model. There is a strange kind of satisfaction in making something decent from such an unpromising starting point.
                    • rtfoe
                      • 9100
                      #25
                      Andy...looks fine. Jim's right, when it's done you'll get that strange kind of satisfaction of having won a battle and you'll be looking for the next challenging kit.
                      • scottie3158
                        • 14221
                        • Holbeach
                        #26
                        It's always fun beating a bad kit into something a lot better and you are doing this.
                        • Wookie2486
                          • 233
                          • Marty
                          • Yeovil
                          #27
                          I have built the dodge beep that was a peerless max kit. It was old but not too bad.
