I have been wanting to build one of these for a while it's took me a while to get all of the p.e and resin bits and bobs together but now I'm finally ready to make a start
Hobbyboss 1/35 scale land rover wmik
You certainly have a lot to keep you busy there Colin. I will pull up a chair if I may and watch you work your magic. Good luck -
Iโm a โLand Loverโ....so you have all my attention!!! :tongue-out3::tongue-out3::tongue-out3:Comment
Hi all, I have been able to get some work done on the wmik over the last week but thanks to 02 I haven't been to able to upload any pictures until today.
The kit is nicely detailed with a complete engine bay it's a shame that I'm going to cover it up.Attached Files- 20181207_141321.jpg (2.8 KB, 0 views)
Well you have been busy Colin! It's all coming together really well. As Scottie says - some nice detailing. Keep it comin sir:thumb2:Comment
Also watching if you don't mind Colin, I have that in the stash,, so will be interested in what you do, and any problems you come across. :thumb2:Comment
Hi guys here's the latest update, sorry it's not been a detailed blog but I have only been able to grab some bench time between the festivities.
So far I have managed to get the chassis body and wheels primed and base coated with XF-61 then a mix of XF-60 and XF-3 (2/1) ratio was applied over the entire model. The chipping was done with masking fluid applied with wire wool.Comment
