1/87 AlsaCast Famo & SWs test builds
Hi Paul, I checked the dimensions on my FAMO, came out to 11.5 scale feet on the outside of the cargo bed. I bought this kit along with an sdanh. 116 trailer about 15 years ago. I suspect it came from CMK in the Czech. Rep. No markings on box or destruction sheet. Did yours come with photo etched detail parts? Looks like you are progressing nicely, will stay tuned for further developments. Rick H. -
Thanks Rick, the Wespe sdkfz 9 is the same as yours, 11.5' & I think it's correct. The AlsaCast 9 is 11'. No PE w/kit. The front suspension was unusable & the front tires & wheels were not correct in my opinion as they were more like an 8 ton's. Working solutions. PaulEComment
I see what you mean about the wheels. I just checked my copy of Nuts & Bolts vol. 12, the only photo that did not have the reinforcing ring was an example at the Military Museum in Dresden. I checked my model and the wheels are the same as yours, imagine that! checked my PE sheet, no rings there, so I will make them with a punch and die set and glue on some nbw castings. Only other possibility I can think of would be to find some Evergreen tubing of the correct outside dia. and miter off a couple of thin cuts and lap them down until thin enough to work and again with the nbw. castings. Hope this helps. Rick H.Comment
Far too technical for me too. I will sit on JR's lap by the stove. STOVE!! - How old are you?? :smiling5::smiling2::smiling3: We call them ovens nowadays mate:thumb2::smiling2:
