1/35 Bronco Gaz-69 2P26 ATM 'Baby Carriage'
    Whilst I'm away from the bench ( poor health ), I've been thinking on what to build next, after finishing my AEW Gannet..............................
    The 2P26 was a variant of the standard Gaz light truck, carrying 4 x 3M6 Shmel Anti Tank missiles. The missiles - NATO name AT-1 Snapper, were first generation wire guide weapons, introduced in 1960.
    I'll put some sprue & detail shots up before I start.
    There is a problem, though it's called 'baby carriage, because of its' resemblance to a pram (?!) - pictures for discussion purposes only Click image for larger version
ID:	1094536Click image for larger version
    The box top shows the hood, foldedClick image for larger version
    But, as a total cop out, the instructions just show the naked tubular frame!, whether in firing, or travel position. Click image for larger version
ID:	1094539Click image for larger version
    I'm thinking of how to represent the folded canvas, my first idea was paper ( as I've used in tarp covers ), but I don't think I can get the folds to lie properly. My next idea is aluminium foil, which I can form, and get to stay in position.
    ANYBODY with any thoughts on how to model this? The frame is quite flimsy, so any solution would have to be lightweight. Just the folded position, you wouldn't want to hide the nicely detailed missiles, and a working version is a step too far!!!!!
    • 15707
    Hi Dave
    First off I hope your health improves and you get back to the bench soon. Cute little truck but looks as though it packs a punch. It does remind me of the hood on those old fashioned Silver Cross prams. Can't suggest anything for the canvas although your aluminium foil idea sounds good.
      Jim,
      I had a diabetic hypo on Thursday ( my own fault! ) - it really knocks me down. leaves me weak & shaky. It usually takes me 4 or 5 days to get over it ( I only manage 2 or 3 a year, thankfully! ). Luckily, I managed to get home before it really took effect & got to my emergency glucose tablets & Mars bar. If it had happened an hour earlier, I'd probably have had a visit to A&E!
      It's rather annoying that Bronco just ignore the folding part of the hood - just a template of the size needed would show that they had thought of it!
      • PaulTRose
        • Jun 2013
        • 6468
        • Tattooine
        if you have any of those little moist wipes used for cleaning glasses, try letting one dry out .............i keep thinking they would make great tarps, dont see why it wouldnt make canvas too
        Per Ardua
          Whilst I am waiting for things to dry on my Gannet AEW, I've taken a few sprue shots & details before any construction starts The parts are well moulded, no flash, perhaps a little overengineered..................Click image for larger version
ID:	1094818Click image for larger version
          One piece chassis - not a very big model, but loads of partsClick image for larger version
          There are two sets of wheels, one road set, another a bit knobblier!
          Slide moulding used - these are the headlight casingsClick image for larger version
ID:	1094811Click image for larger version
          Floorpan & cab backwallClick image for larger version
          2 of the missiles
ID:	1094815Click image for larger version
          The frames for the pram top........................Click image for larger version
          Hmm not sure that really works, but........................Click image for larger version
          PE & decals
          One option - Russian Green! Given that the 2P26 was operated by most Warsaw Pact Countries, and others, like Syria & Egypt, that's a little disappointing - I'll have to kook around for some alternatives. Construction will start shortly
            There are photos of these finished in sand over olive drab (I think) which would be an option for a more colourful scheme.
              Construction under way. I seem to have spent a few hours at the bench, and not a lot to show for it. This is mainly due to the PE - I was determined that I was going to use the supplied PE.......
              I'm not really sure why PE was used, there are similar all plastic parts on the sprues - it just makes it trickier!Click image for larger version
              These two PE brackets surely could have been moulded?
              Anyway - after a lot of holding my breath, and tweezer work Click image for larger version
              The engine is a multi-part assembly - none of which will be seen, as I intend to have the bonnet closed - it's needed, though to locate the exhaust pipe, radiator, and drive shaft!
              It's not going to be very big, just over 110mm long x 60 wide.
              Here's the state of play for today - it all seems to be rather fragile, I think I'm going to have to strengthen the joints, with drops of CA Click image for larger version
              I'll leave this overnight, to really harden off then more suspension bits.................
                Continued assembly - The Bronco instructions can be pretty vague about positioning parts - I've left off the steering arm - that joins up with the steering column, which isn't fitted until about 6 stages later!Click image for larger version
ID:	1095141Click image for larger version
ID:	1095142Click image for larger version
                You have to dry fit the parts several ways - to find the correct position - the exhaust pipe is like this- it isn't clear that whether it goes inside or outside the chassis - and all the subsequent assembly drawings show the vehicle from the other side! The chassis is now complete, and I can move on to the floor pan
                  Even for a chassis that looks quite busy, I must say.
                    One thing I've noticed - I don't know if it's an error, but there aren't any shock absorbers. It could be the GAZ was really rustic, but I would have expected to see them on a vehicle that carried missiles around..........
                    • stillp
                      • 8094
                      • Pete
                      • Rugby
                      Probably lever arm shockers Dave. Aren't they the bits that connect to the PE near the centre of each spring?
                        Aren't they the parts linked by the PE? Not telescopic shock absorbers like we have these days, but the lever arm type
                        Oops, beaten to it :smiling5:
                        • stillp
                          • 8094
                          • Pete
                          • Rugby
                          There's an echo in here isn't there? :smiling5:
                            What can I say, I'm a slow typist lol
                              Hmm - could be, but they look far too weedy to absorb any shock - I thought that they might be chassis lubricators, but Russian Automotive engineering isn't my strong point!
