Thinking about it some more just now, I’m wondering: how big are those hubs? If they’re large enough (without the tyres) that they will all touch the ground if you put them on the axles, then it’ll probably be better to put the hubs on first because that way, you can line them up more easily without the cab etc. to get in the way. In that case, putting the front and rear hubs on and placing the model on a glass plate will let you add the ones for the middle two axles nicely lined up with the rest.
1/72 MAN 8x8 Truck
I like your thinking but the hubs are slightly too small to reach the ground, and the wheels and tyres are moulded as one, so your idea won't work in this case. I've just been out to take some pictures to better show what I mean.
[ATTACH]343229[/ATTACH]
I've got the axle height sorted as best I can, here they are on a flat ceramic tile, so I shouldn't need to worry about that too much.
[ATTACH]343230[/ATTACH]
More tricky is how they align squarely, as in camber and toe angle. Any tiny amount of deviation in the small hub (and there is lot of play in the hub-axle joint) will be magnified when I put the larger wheels on (no play in the wheel-hub joint). So for that reason I thought it best to build the wheel/tyre/hub assembly as one, which will then give me plenty of wiggle room when I finally fit them on (utilising the play in the hub-axle joint). :smiling3:Comment
Ah the joys of trying to keep a chassis square. Looks like you have done a great job. I'm sure all the wheels will sit level once addedComment
Oh well, it was a good idea, just not for this model I suppose.
Not much to show on this but I finished work a bit early today so managed to make a start on painting the wheels. For some reason I have an extra spare so will try and work it in somehow.
Also pictured are some of the smaller parts I've been working on. Assembling, cleaning up the seam lines, filling pin holes, and priming with either Mr Finish Surfacer or Surfacer 500 depending on how much sanding they've had.
[ATTACH=CONFIG]n[/ATTACH]
Something I hadn't noticed until now is that this kit has absolutely no dashboard or instrument panel. In fact the interior is empty apart from two seats and a steering wheel. Looking at reference shots there's normally plenty of stuff inside the cab, even a fold down bunk bed, so I've ordered some assorted plasticard and will have a go at making a few things myself.Comment
You have taken to this like a duck to water, including joining in so well on the Forum.
I think you should become a member of the Honorable Order of the Rabble, more commonly known as the Rabble .
Great work, enjoying this .Comment
Thank you John! I'd be honoured to join the ranks.
Is there a special handshake to learn or should I simply model with one trouser leg rolled up? :smiling5:Comment
