If the filter works then there may be something in the particles theory.
1/72 MAN 8x8 Truck
No problem at all John, if this discussion helps me and others then feel free to keep it going :thumb2:
The filter I have could be considered pretty coarse in the airbrush world, 200 micron is the size of my airbrush nozzle after all! I've seen them down to 90 microns which would be even better, but I'll see how I go with what I've got for now.Comment
Evening Andy,
Thanks Si. I think I mentioned in my rant that I'd tried with and without their flow aid/improver but it didn't seem to help. Are you using it as well as their thinner, or instead of? I'm sure somewhere along the way I tried every combination but it would be good to know. Can I also ask what airbrush and nozzle set up you use out of interest?
When I see the great work that you and others do with these paints it makes me even more frustrated that I'm having these issues. It's clearly something I'm doing wrong, but I haven't found out what yet lol.
Hi Andy,
This is all interesting stuff:nerd:. In answer to your questions....I used the Vallejo paint without airbrush thinner, just water and flow improver. I can’t honestly remember ratios.
The Mig AMMO paints I used with their own thinner and a drop of Vallejo flow improver. I tend to mix by eye. I do remember still getting some tip drying though so not perfect!
My airbrush is an Iwata revolution BR with 0.3mm needle and I use about 25psi.
I’m inclined to think the moons position and day of the week have an influence on paint flow too:smiling5:
Hope this helps:thumb2:Comment
I'm trying to make this look slightly dusty / sandy. I'm sure there are plenty of magic potions that could do it for me but for now I'm stuck with oil paints, so trying to build up gradual layers of a sandy coloured mixture. Obviously this is all new to me but I think it's starting to get somewhere. Maybe a few more days / layers around where it would collect most?
[ATTACH]345131[/ATTACH]
[ATTACH]345132[/ATTACH]
[ATTACH]345133[/ATTACH]Comment
Desert, & semi-arid environments will lighten western-Europe camo to the color of the local soil/sand. Where it collects will depend on whether it is loose or compacted. Loose soil/sand will become airborne easily and collect on upper surfaces primarily where compacted soil/sand will be drawn up by tires and collect primarily within fenders. HTH. PaulEComment
Thank you chaps. I'm guessing dry pigments would build up a more convincing effect more quickly, but working with what I have I'll try to keep building it up on the areas mentioned, without going overboard.Comment
The simple way is washes of the dirt colour you want, thicker around the lower parts of the vehicle and thinner towards the top. These sorts of vehicles can be anywhere between pristine (in the garage, mainly) and completely filthy (on exercise), so you can pretty much go for any amount of weathering you care to apply.Comment
Hi Andy
Despite your misgivings the paintwork looks great. Really starting to look the part.
For a dusty look often pigments work well. On a matt surface simply rubbing in pigment with a cut down brush can be very effective. No need to fix the pigments although they won't stand heavy handling.
JimComment
If you are persevering with oils for your dust work then your beige, light browns and whites are great for dust work if you drybrush edges and dry brush streaks. Try it on an old model and see how you get on before applying it to the main buildComment
Thanks for the tips chaps. I may end up succumbing to dry pigments but I'll see how I get on with oils first. The boss is already starting to take note of every new product I buy so need to keep things under the radar for a while :smiling5:Comment
You'll just have to get used to that and just aim to make each model better than the last one: you're on an asymptotic curve - you will get nearer and nearer to perfection but never actually achieve it. How's that for 4am thinking!? Past my bedtime methinks.Comment
Now I DEFINITELY know you're new to modelling Andy! SWMBO will know more accurately than you do just how much you have spent, and will remember the time/date of each purchase no matter how cleverly you try to hide it!!!Comment
Haha, I'm sure you're right there Dave. And in 5 or 6 years time when she's trying to negotiate for a new kitchen appliance I will get the old "don't you remember the day you spent x on y..." :smiling2:Comment
