Another stunning Scottie special. Your building work is beautiful. The doors are stunning. I am sure you still have more to go with you distinctive attention to detail. Don't forget the leaves :thumb2:
I see you even get a form to make them. Too good (my wallet, my wallet) to be true!!!
Allen, look at it this way you cant take your money with you :tongue-out3:
Originally posted by Andy Belsey
Excellent Paul, especially those doors!
Andy
Andy, Coming from you that is good enough for me.
Originally posted by boatman
Yes Scottie some wonderfull work an detail id be hard pressed to match it WONDERFULL :thumb2: :thumb2: :thumb2: :thumb2: :thumb2:
Chris
Chris, Thank you mate really appreciate the comment.
Originally posted by Mickc1440
What can I say Scottie, you've simply outdone yourself with those doors, great work
Mick Thanks mate I have enjoyed doing them.
Steve, Thank you mate, I try to re create what I see sometimes it works and other times It is beyond my skills but I keep trying.
Scottie, the doors are excellent and detailed down to the bolts and horse shoe. Love the weathering. You ought to write a book on your techniques as Peter has said. The stone house is looking better with these doors.
Richard thank you really appreciate the comment.
Originally posted by Jim R
Hi Scottie
Well I reckon that building is superb. The doors are spot on and using the styrene sheet was a good choice.
Jim, Thank you mate it is useful stuff I enjoyed making them. there are a few issues with them which I will take on board for the next time I make any
Originally posted by Si Benson
You never fail to produce quality buildings, Iโm blown away by the doors....blooming marvellous :smiling4:
Si Thanks very kind of you to say.
Originally posted by Wouter
Nice work indeed, I especially that weathered wooden door
It is slowly coming along. Added some flashing to the tiles.
Next I have made some guttering from Pewter, metal tube and green stuff. I decided on the green stuff as try as I might I couldn't get the bends right using plastic or metal tubes, boiling water, direct heat and even using small springs as a plumbers spring didn't work.
Not perfect but when painted up and weathered it should look ok.
Hi Scottie
Guttering looks good. Opportunity for some nice staining on the wall from leaks :smiling:
I am another who can't bend metal or styrene tube. Doesn't matter what I do or how much I swear at it it either kinks or springs back out of shape. Using the putty was a very good idea. It has worked well. Is the flashing thin pewter sheet - looks good.
Hi Scottie
Hi Jim,
Glad you like the guttering, in hind sight I could have tried bending solid styrene an idea for next time. The weathering is always a part I enjoy. he flashing was silver foil from around a chocolate bar.
