not stew again.
  • spanner570
    • 15482
    #226
    Lovely work Paul.
    I'm about to start my European cart which came with paratroopers and 'Family' to go in my dio. So my note book is out if you don't mind.
    Sorry for the elbowing chaps, but I need a front seat.
    • scottie3158
      • 14245
      • Holbeach
      #227
      Lovely work Paul.
      Thanks Ron,
      It's not the best kit in the world but it scrubs up ok. With your skills you will do a cracking job.
      • spanner570
        • 15482
        #228
        ....OOPS! Got it wrong again. My cart is totally different to yours. It's still wood though, just a different shape....should have gone to specsaver.
        • scottie3158
          • 14245
          • Holbeach
          #229
          Lol, the principles will be the same. As to specsavers I thought I had glued something on upside down but I hadn't.
            That looks cracking. Very nice Paul.
              Just simply wow to everything Paul :smiling3:.
              • scottie3158
                • 14245
                • Holbeach
                #232
                Thanks Andy.
                Ralph, Thanks fella.
                  That cart is b****y amazing Scottie. Absolutely beautiful.
                  • scottie3158
                    • 14245
                    • Holbeach
                    #234
                    Peter, Thank you mate glad you like it.
                    • Mickc1440
                      • 4786
                      #235
                      You certainly are pushing yourself mate, excellent detail on the woodwork.
                      • scottie3158
                        • 14245
                        • Holbeach
                        #236
                        Thanks Mick, that is really kind of you to say. Given the quality of builds on here you have to push just to keep up.
                        • Wouter
                          • 742
                          #237
                          Hi Paul, that cart and fieldkitchen look good, nice work!
                          • scottie3158
                            • 14245
                            • Holbeach
                            #238
                            Thanks Wouter, glad your looking in.
                            • BigGreg
                              • 2186
                              #239
                              I'm quite happy with the cart. The metal work had been picked out with black grey mixed with a little oily steel. When this was dry the bolt heads where picked out with the same mix but lightened a little with some light flesh. When it had dried a wash was added to pick out the details then finally a bit of dry rust pigment was added.
                              [ATTACH=CONFIG]n1101086[/ATTACH]
                              [ATTACH=CONFIG]n1101087[/ATTACH]
                              [ATTACH=CONFIG]n1101088[/ATTACH]
                              When the oils have fully dried it will receive a coat of matt clear to remove the shine.
                              Next I will be working on the lean to on the side of the house.
                              cheers
                              Scottie
                              I mean you are happy.... you should be... this is BEAUTIFUL... fantastic...
                                Say no more Paul. :thumb2::thumb2::thumb2::thumb2::thumb2:
