not stew again.
  • SimonT
    • 2824
    #271
    This is looking really good Scottie :thumb2:
    I had a similar vision for a shed type building at some point in the future and bought a load of Historex spares last time I put an order in. Brooms, pitch forks, barrels, a donkey etc etc
      • 15799
      Hi Scottie
      Just have to agree with all the comments. Superb - you keep raising the bar.
      • scottie3158
        • 14245
        • Holbeach
        #273
        Simon, Glad your liking it so far. I looked at a few sets of "Farm tools" but as these will only be seen in directly thought I would scratch them this time and raid the spares box. I look forward to seeing your take on the shed, I'm sure we will be in for a treat.
        Originally posted by Jim R
        Hi Scottie
        Jim,
        You are to kind mate.
        • scottie3158
          • 14245
          • Holbeach
          #274
          Hello all you die hards that are sticking with this. The wood work received a dry brushing of whit oils mixed with a touch off black and burnt umber, then another brushing of the same mix but less black. This is the first time I have tried this and quite happy but there is always room for improvement. When totally dry it will receive a matt coat. I still have to add the nail heads.
          Next a mixture of scratched and bits from the spares box were painted up. Not to worried about them as they will be inside the shed to form a bit of clutter.
          Apologies for the bad pictures not an art I have mastered.
          Scottie
          • minitnkr
            • 7574
            • Dayton, OH USA
            #275
            You've certainly captured the used & abused look. Well done. PaulE
            • scottie3158
              • 14245
              • Holbeach
              #276
              Thanks Paul, Glad your looking in.
              • scottie3158
                • 14245
                • Holbeach
                #277
                Not a lot done and I apologise for the bad photo I will try and take a better one later. I have attached the lean to, to the building but prior to that I ran some green pigments into the stonework. The oil drum was positioned in the back corner and some old planks of wood lent up against it. The tools were then hung on the posts.
                cheers
                Scottie
                  Looks totally convincing Scottie - you wouldn't know it's a model.
                  • scottie3158
                    • 14245
                    • Holbeach
                    #279
                    Thanks Peter that's why I keep the pictures blurry.
                    • scottie3158
                      • 14245
                      • Holbeach
                      #280
                      Looks like even the die hard followers have given up on this :tongue-out3:
                      I have started on the base but still not 100% sure what I am going to do. I have laid out the main items and fairly happy with it the cart may move further into the corner under a tree I plan to put a there. The wall needs to be fixed and weathered. The base will also receive some texturing to give it some lumps and bumps.
                      cheers
                      Scottie
                      • Mickc1440
                        • 4786
                        #281
                        Absolute master class mate.
                        • Wouter
                          • 742
                          #282
                          Top notch indeed!
                          • Allen Dewire
                            • 4741
                            • Allen
                            • Bamberg
                            #283
                            No my Friend, we haven't given up.........โ€ฆ.We are just blown away by your fantastic work and don't know what to say!!! This is just so great and so well done Paul...
                            A Big Prost
                            Allen
                              Exactly. Plus I don't want to peak too soon and use up all the superlatives when we still don't know what stunning work is around the corner.
                              I'm following each post with interest and always looking forward to the next episode :smiling3:
                                • 15799
                                Hi Scottie
                                Superb modelling. Bet you're dead chuffed with the way this is going.
