Turning into another work of art Scottie.
not stew again.
Paul .I love the way you ," just cobbled together a hinge system :flushed::thumb2::thumb2::thumb2:
Said in true R.E.M.E. fashionComment
Thanks Peter, Not sure about art unless it's abstract
Thanks John, Appreciate the kind words, AeMComment
Paul. Great start and very interesting build Iโll be sitting next to John with my spoon and napkin. Yes turn on the heat a little very cold here for JuneComment
Just a small update. I replaced the coffer grinder handle with a cranked version. For strength I drilled out both ends and used copped wire to secure the handle and both ends. The hasps were modified and the third one added. I didn't have another etch one so made it out of a bit of evergreen sheet. I also removed the very badly moulded weld beads and replaced then with stretched sprue.
On the other end I have added a crank handle which I presume locks the brakes on. This was again added form some flattened copper wire and drilled out both ends to accept a bit of copper wore for strength.
cheers
ScottieComment
Yes, I think I need a cat sat on my desk like wonwinglo has. That might just be fast enough to catch them!Comment
Scottie, your detailing makes sense of all those funny little lumps and bumps that had me wondering. Great stuff.Comment
