not stew again.
I'm drooling and not because of the smells of whats cooking. These are details I wished I had the patience for. Scottie, you're cooking up a scrumpshess mobile kitchen. You'll have a long line of hungry Germans waiting for their meal. I see John and Steve also waiting in line...hey whose side are they on. :tears-of-joy:
RichardComment
Thanks Lee, glad to see you sticking with it.Comment
The cook part of the build is now pretty much done some more details added, again not 100% correct but hopefully will add a little. These include hinges made from pewter and copper wire. Latches for the lids from the etch box. the trail leg had the solid clamp removed and a new one scratched from plastic, copper wire and a scratched chain. The wheels has a lot of seams so these were cleaned up a woodish grain scratched in and metal rims added. There are also some detail added to the hubs. The wheels are not glued yet so I can remove for painting. One thing I have noticed is I have knocked part of the handle off the coffee grinder so I will need to replace that.
Next I will be moving on to the limber.
As always thanks for following and pointers welcome.
ScottieComment
Scottie,
When you mention Pewter is that the Same as lead foil and where do you get it from.
MartyComment
Hi Marty,
No it is different from lead as it is an alloy of tin and copper and a few other things or though you can get some with lead in it. It is soft enough to work with but a bit stiffer than lead so holds its shape better. To help it stick I always roughen the surface with a scourer of scratch it with a sharp blade. I got mine from evil bay but there are lots of places to get it. It comes in various thicknesses and a sheet will last for ages. HTH.Comment
Scottie,
Thanks mate I am gonna have a look now. Do you know the best sort of thickness to get.
By the way forgot to mention it but the rims look really good mate.
MartyComment
No worries, The stuff I have is 0.3mm but other sizes are available and I need to get some more.Comment
I agree with Neil. Some wonderful work Scottie. You really are pulling out the stops on this one.Comment
Scottie,
Thanks mate, as everyone else has said your build is fantastic and I can't wait to see your figures.
MartyComment
Thanks Neil as long as their not in the stew :tongue-out3:
Thanks Martyn, They are a way off yet but hopefully I will do them justice that is the pointComment
