not stew again.
  • Steve Jones
    • 6615
    #106
    Found these while surfing today
Name:	Bundesarchiv_Bild_101I-258-1319-36,_Südfrankreich,_Verpflegungskolonne_auf_Landstraße.jpg
ID:	1098788Click image for larger version
    • scottie3158
      • 14221
      • Holbeach
      #107
      Steve thanks mate it shows a bit more detail I can add to the chimney.
      • scottie3158
        • 14221
        • Holbeach
        #108
        I have remade the building as I wasn't happy with it. I had purchased a self adhesive stone wall effect that said it was embossed and looked fairly good on the web. When it turned up it was very well printed but tended to repeat the pattern to often and wasn't embossed just smooth. I applied the print to the building but when I tried to press the detail in the effect was not what I was looking for, especially at the corners of the building. So this time I made the building out of my old favourite the blue foam. It was made to the same dimensions as before. This time using the print as a guide I have patterned the foam my self using a pencil. This has now received a coat of watered down PVA to seal the surface. Its a bit rough looking but hopefully when it is painted up and the details added it will pass muster.
        comments as always welcomed.
        Scottie
          • 15746
          Hi Scottie
          Building MK2 looks great. Love that blue foam stuff. Look forward to the figures. Added details on the kitchen worth the effort.
          • scottie3158
            • 14221
            • Holbeach
            #110
            Originally posted by Jim R
            Hi Scottie
            Jim,
            Thanks mate appreciate the kind feedback.
            • BigGreg
              • 2183
              #111
              the building looks super realistic.. keep on doing what you are doing looks AWESOME.. ;-)
                It don't look rough to me. Great work Scottie.
                • JR
                  • May 2015
                  • 18273
                  #113
                  Superb Paul. Absolutely nothing amiss there .
                  • SimonT
                    • 2824
                    #114
                    Looks great - should paint up nicely
                      The building looks great Paul :smiling3:.
                      • Si Benson
                        • 3572
                        #116
                        Wish I had a pinch of your ability and enthusiasm, the building looks awesome already and it’s not even painted!
                        • rtfoe
                          • 9101
                          #117
                          Hi Scottie, the building looks good...better than the stone detail I did on mine with the same technique...the scored foam is so much easier than puttying or plastering.
                          • scottie3158
                            • 14221
                            • Holbeach
                            #118
                            If it turns out half as good as your last scene I will be happy mate.
                            Thanks Peter not to bad if you follow the 2foot rule.
                            Thanks John, you have set a high bar with your buildings.
                            Thanks Simon hopefully it will be ok.
                            Ralph thanks mate.
                            Si, your to kind mate I have no more ability than anyone else on here but do enjoy what I do.
                            [ATTACH alt="387482.jpg"]349365[/ATTACH]
                            Richard, Your ruined building looked great mate but as you say the foam is easy to use and gives fairly good results.
                            • Steve Jones
                              • 6615
                              #119
                              You need to come down to Devonshire and repair some of our granite walls on the moor LOL. A fine piece of block work. Very impressed with the pointing. Good luck painting that LOL
                              • Mickc1440
                                • 4779
                                #120
                                That building certainly doesn't look home made Scottie, very nice detail.
