hope this is in the right place !, this model to be built next started this a few months ago so I thought about time this was finished ! loads of parts including a set of photo etched parts ,
Tamiya 'famo' 18 ton halftrack
Tags: None
sorry pictures are not to clear, these are a few of the assembled parts ready for detailing. just been reading through the instructions and found one mistake it ,the road wheels all come in two halves which are to be cemented together then fitted to the axles once cemented together you can't fit them all on as they are supposed to sort of overlap each other but you cant fit them on this way,best way is to fit inner halves to axles then cement the outer halves in place !Attached Files- 135 scale tamiya ' famo' 18 ton halftrack suspension parts.jpg (2.8 KB, 1 view)
- 135 scale tamiya ' famo' 18 ton halftrack suspension parts.jpg (2.5 KB, 1 view)
- 135 scale tamiya ' famo' 18 ton halftrack front axle parts.jpg (3.3 KB, 1 view)
- 135 scale tamiya ' famo' 18 ton halftrack front axle complete.jpg (2.3 KB, 0 views)
- 135 scale tamiya ' famo' 18 ton halftrack 22 ton winch parts.jpg (2.3 KB, 0 views)
- 135 scale tamiya ' famo' 18 ton halftrack gearbox.jpg (2.1 KB, 0 views)
- 135 scale tamiya ' famo' 18 ton halftrack coupling parts.jpg (2.2 KB, 0 views)
- tamiya 'famo' 18 ton halftrack chassis and suspension fitted.jpg (2.8 KB, 1 view)
If you have glued the wheels together. You can get them on the axles by standing the wheels up in the "assembled" position and place the chassis alongside and carefully move them into place and press onto the axles....
Ask me how I know... O.oComment
Just keep the outer faces of the wheel axes clear of paint (or scrape it off, of course), then install them like you say — you can still glue the inner and outer halves together fine.Comment
a couple of photo etched parts fitted to headlights and engine, also some track partsAttached Files- headlights and photo etched mounting plates fitted,.jpg (2.4 KB, 1 view)
more photo etched fitted, bit of tidying up to do and then be ready for painting , brackets fitted to bottom of body bit more tidying and painting to do !Comment
forgot to put a picture of what its supposed to be like, so here it is !Attached FilesComment
done some of the track just waiting for glue to dry plates now fitted to both drive sprockets,what a fiddly job that was but got there in the end !Comment
pic 1 and 2 tying down eyes, brackets,,strap with buckle , and two floor mounted brackets pic 3 tool tray and locker clasps, pic 4 body side with door tie down eyes pic 5 mudguard hinge pic 6 air filter clampsAttached Files- more photo etched parts fitted (1).jpg (1.9 KB, 1 view)
some more parts completed,some really fiddly etched parts !Comment
