Scotties taking a Liberty
  • scottie3158
    • 14201
    • Holbeach
    #61
    Originally posted by outrunner
    Just loving the engine detail, great work!
    Andy.
    Thanks Andy glad you like it
    • scottie3158
      • 14201
      • Holbeach
      #62
      slow progress but chipping away. Rebuilt what I believe is a tank of some sort fuel/oil? Made the "USA" from fine wire not perfect but it looks ok to me,
      then some work on the bulk head. added some cables for interest not strictly accurate as I can't see clearly where the wires go. the pipe on the RH side of the bulk head will go from the carbide generator to the lamp.
      The tie downs are from copper wire.
      Added a little detail to the instrument panel my reference pictures showed another dial and a big switch in the middle. Not easy to see in the picture.
      cheers
      Scottie
      • Steve Jones
        • 6615
        #63
        Thats a lot of chipping mate! Up to your high standards I see. I dont envy you doing "USA" :smiling5: . Glad it turned out well. Dont loose those letters now:smiling5::smiling2:
        • scottie3158
          • 14201
          • Holbeach
          #64
          Cheers mate, luckily they have stayed put.
          • scottie3158
            • 14201
            • Holbeach
            #65
            I added a piece that again I don't know what it's for but again it looks like a filler of some kind but it also has a linkage of some sort I think it might be for clutch or brakes.
            One of the steps was broken plus they were very thick so I removed them and they were replaced with flattened copper wire and punched rivets. A slot was cut into the rivet to represent a screw heads.
            A very bad picture showing the link painted and fitted. the cab has also had a coat of paint. The paint work still needs a lot of work, but some of the details have been picked out. The high lighting on the frame appears very yellow but is no where near as bright as that.
            I also picked out some of the details on the inside but again lots of work to do.
            I will try and post some better pictures later when I have added more details.
            cheers
            scottie
              • 15683
              Hi Scottie
              Quality all the way. Attention to detail and skill.
              • scottie3158
                • 14201
                • Holbeach
                #67
                Originally posted by Jim R
                Hi Scottie
                Thanks Jim glad your looking in.
                • BattleshipBob
                  • 6792
                  • Bob
                  • Cardiff
                  #68
                  Stunning again Scottie!!
                  I struggle to spell USA lol
                  • scottie3158
                    • 14201
                    • Holbeach
                    #69
                    Thanks Bob glad your looking in
                    • BigGreg
                      • 2182
                      #70
                      and another wonderful installment...details are awesome... ;-)
                      • scottie3158
                        • 14201
                        • Holbeach
                        #71
                        Greg, thanks mate I'm enjoying this.
                        • JR
                          • May 2015
                          • 18273
                          #72
                          Hi Paul.
                          Had a catch up, has your stamp of quality modelling all over it.
                          How did you coax those pieces of wire to stay in shape before you glued them down ?
                          • SimonT
                            • 2824
                            #73
                            Love the screw heads on the steps - very nice detail :thumb2:
                            • BigGreg
                              • 2182
                              #74
                              we can see it...
                              • Mr Bowcat
                                SMF OG
                                • Dec 2016
                                • 4600
                                • Bob
                                • London
                                #75
                                Only just seen this thread Paul, up to your usual high standards I see.
                                Si vis pacem, para bellum.
