Ford GPA
  • scottie3158
    • 14198
    • Holbeach
    #46
    Originally posted by Lee W
    Oh! What happened? I've missed this one...???
    Right, I'll pull up a bollard and watch from a distance, not to far mind, I want to see what you're doing :nerd:
    Lee
    No worries mate good to have you along don't look to closely you will see all the mistakes.
    Originally posted by BigGreg
    Better and better...well done and keep on doing... :smiling2: :smiling2: :smiling2:
    Thanks Greg.
    • Steve Jones
      • 6615
      #47
      Another excellent update Paul. I'm enjoying this nearly as much as you are. LOL. Keep up the great work
      • JR
        • May 2015
        • 18273
        #48
        Originally posted by Mini Me
        You know me, I'm a glutton for this sort of thing...is there any seating left?...and I'm not sitting next to JR, he always drools when he nods off. By the way, where is the old goat?:tongue-out3:
        I'm here right behind you !
        Just arrived Paul , looks as if it's going to get crowded.
        • SimonT
          • 2824
          #49
          Cracking stuff Scottie
          I didn’t have an etch set for mine - do you get the mesh screens for the openings next to driver and passenger? Think I made mine from net curtain
          I see you started on the back end - you may already have it in hand but just in case, there should be a seam flange running around the perimeter of the prop recess
          • scottie3158
            • 14198
            • Holbeach
            #50
            Hi Steve, glad to know your enjoying it as well
            Hi John, Good to have you along.
            Hi Simon, Yes you do get the mesh screens included in the set. Thanks for pointing out the seam I will add this as well.
            • scottie3158
              • 14198
              • Holbeach
              #51
              Not much done today but what was done was quite fiddly. The headlamps hang from the guards, so I had to fill the holes in the plastic lamp bodies and oles drilled in the back for the cable. The etch was part formed then the lamps were stuck to the frame, when this was dry the cable were added to the back of the lamp and the rest of the etch was formed to shape. A hole was drilled in the body of the jeep for the other end of the cable. the whole lot was then CA'd into place. Just for a bit of interest I added the clear lens to one light but the other one I hollowed out and added some wire to show the lens being broken. Finally the securing bolt was shaved of the kit part and glued on top.
              Next all the moulded detail was removed from the, I don't know what its called. And replaced with the etch parts.
              I still have the detail to add to the handle.
              Scottie
              • The Smythe Meister
                • Jan 2019
                • 6248
                #52
                Blinkin,blimmim eck........
                Just getting better and better Scottie,that sure is some intricate modelling right there:flushed:!!
                Cracking stuff mate,
                Andy
                • Neil Merryweather
                  • Dec 2018
                  • 5182
                  • London
                  #53
                  lovely stuff Paul
                  • Steven000
                    • Aug 2018
                    • 2824
                    • Steven
                    • Belgium
                    #54
                    Shiny details Scottie, I like the idea of the broken lamp :thumb2:.
                    Looks all very fiddly indeed, have fun!
                    Steven
                    • BigGreg
                      • 2181
                      #55
                      .. and i'm becoming repetitive.... but your skills are stunning... show us MOOORE MOOOOOOOOORE :smiling6: :smiling6: :smiling6: :smiling6:
                      • tr1ckey66
                        • Mar 2009
                        • 3592
                        #56
                        Hi Paul
                        Missed out on this till now. Very nice detail work on the GPA. Loving the PE and other scratch details. I'll be very keen to see how this turns out as I have this kit in the stash which I've earmarked as part of the load for a 1/35 LCT4.
                        Great work
                        Paul
                        • scottie3158
                          • 14198
                          • Holbeach
                          #57
                          Andy
                          Andy, Thank you happy you like it.
                          lovely stuff Paul
                          Glad your sticking with thank you.
                          Steven
                          Thanks Steven I just thought it might add a bit of interest but I think I need to find some finer wire for the internals.
                          Greg, please mate i am blushing here, but glad you like it.
                          Originally posted by tr1ckey66
                          Hi Paul
                          Great work
                          Paul
                          Paul, welcome aboard the kit shows its age but does scrub quite well with a bit of work. I look forward to seeing your take on this and the combined build with LCT4.
                          • tr1ckey66
                            • Mar 2009
                            • 3592
                            #58
                            Hi Scott
                            It does look typical Tamiya of its age. And actually that's alright in my book. The PE obviously helps and the odd scratch detail can fill any voids.
                            Superb stuff
                            Paul
                            • scottie3158
                              • 14198
                              • Holbeach
                              #59
                              Hi Scott
                              Superb stuff
                              Paul
                              Paul,
                              I would rather make an old kit and try and make it better anytime over the new over engineered over priced offerings today.
                                More fine detailing Scottie. Thought of you watching 'Indiana Jones and the Kingdom of the Crystal Skull' - the Soviet ZIZ 485 used in the film was based on lend-lease DUKWs.
