Ford GPA
  • scottie3158
    • 14202
    • Holbeach
    #91
    The build is pretty much done now. Everything has received a coat of Tamyia light grey. I don't normally bother but as there was so much etch I wanted to tie all the surfaces together. When this has dried properly I will do the pre shading.
    Just seen a hair that needs removing.
    cheers
    Scottie
    • JR
      • May 2015
      • 18273
      #92
      Looks good Paul, do you prime that etch with Mr Hobby, or not bother.
        • 15704
        Hi Scottie
        Looks good under primer. Shows up the detail you've added.
        • scottie3158
          • 14202
          • Holbeach
          #94
          Hi John, I don't bother with primers of any kind the only reason for the light grey this time was to balance all the finishes out as there is a lot of large etch areas.
          Originally posted by Jim R
          Hi Scottie
          Thanks Jim, it also shows up all the mistakes.
            Beautiful work Scottie.
              Scottie,
              Just caught up on your build, had a good read through and what can I say except impressive.
              Mike.
              • wotan
                • May 2018
                • 1150
                #97
                C'est pas beautiful ca? As we say in Quebec franglais. Nice one Paul.
                • scottie3158
                  • 14202
                  • Holbeach
                  #98
                  Thank you Peter.
                  Originally posted by MikeC
                  Scottie,
                  Mike.
                  Thanks Mike, really appreciate it.
                  • scottie3158
                    • 14202
                    • Holbeach
                    #99
                    Thank you John, glad you like it. As Del boy a much loved character here would say mangetout
                    • BigGreg
                      • 2182
                      #100
                      well... it's perfect for the OD... can't wait..
                      • scottie3158
                        • 14202
                        • Holbeach
                        #101
                        Cheers Greg
                        • adt70hk
                          • Sep 2019
                          • 10409
                          #102
                          Oh my that is looking very nice indeed.
                          Very well done Paul.
                          ATB
                          • scottie3158
                            • 14202
                            • Holbeach
                            #103
                            ATB
                            Cheers Andrew, it's coming together slowly
                            • Steve Jones
                              • 6615
                              #104
                              Nice to see the wet stuff Scottie. It really has tied everything together really well. Its a lovely subject to build.
                              • scottie3158
                                • 14202
                                • Holbeach
                                #105
                                Thanks Steve I'm glad you like it. It is a simple build but full of detail and something different.
