I have added the initial wash to the cab walls. Prior to this I added an interior light and cable to the back wall. The seat backs and details all need to be picked out.
Next door handles were added to both doors. The model just had a simple square block that was to small and to far down.
The cab floor also received the same treatment again details require picking out.
Thanks mate glad you like it. Where did you keep the snatch blocks?
Paul,
Snatch blocks were kept in those front baskets under the drivers and crews doors, along with a few chains and shackles. Too heavy to have snatch blocks any higher.
Love the internal cab work .
Paul,
Love the internal can work .
Thanks John, I thought it would be a pain to lift them in and out of anything above head height lol.
I have finished off the cab interior just needs a coat of flat. Just added a map and a magazine wedged between the seats for a bit of interest. The rifles have been added with the addition of some slings from masking tape. The windows have all been masked on the outside hence the yellowish look.
I also decided to add a bit of dirt under the back before It gets placed on the chassis and becomes difficult to reach. there will be more work done later.
