Hi all,
I've done a couple of models from this Military Miniatures series but they were fairly quick, simple things. This one has a little more to it (including 6 figures :flushed
, and since I have nothing else to build I thought I'd bore you all with a blog of it.
If you wish, the sprue shots can be seen below
Figures
PAK & main chassis
Wheels, suspension, front end
Rear body parts
First job in the instructions was the assemble the rear body, with benches for the troops and ammo boxes
Then to the rear suspension, which is quite detailed for the scale
Chassis, suspension and exhausts brought together with rear body
Then the pit
And finally the front end, grille and windscreen
These were all dry fitted, but I haven't glued the sub assemblies together to make painting easier
The gun was also a quick job to build
It was all stripped back down and all parts were given a coat of primer, including the accessories, then the gun and main body received a coat of Mr Color German grey, to act as a base.
After our daily stroll around the exercise yard I mixed up a lighter version of the colour from Model Air German and Medium greys to start building up layers with some highlights
More to come tomorrow, but a decent days work I think.
Notice the figures are still in the box lol, I might pluck up the courage soon....
Figures
PAK & main chassis
Rear body parts
Then the pit
