It's strange Dave, the smell of cellulose / lacquer paints doesn't bother me in the slightest, but open up some white spirit, so-called odourless thinner, or a tin of household gloss paint and my head is spinning and I start feeling bilious!
So I carried on with the load bed today. I'd left the mudguards off since they were a different colour, and also I'd spotted this issue early on in the build:
[ATTACH]388819[/ATTACH]
Both of the duplicated F sprues were the same, breaks in the delicate stays for the more forward mudguards. The others for the rearward ones were fine as they were deeper within the sprue. I thought about replacing them but with the angles being so critical to the positioning I just cemented them together the best I could.
It must have worked as once sprayed black, they fitted fine to the bed, lining up well. I also fitted the tools etc. that I'd painted earlier. Thanks to a few tips from Mr T I'm getting more confident with using CA glue to fix pre-painted parts.
[ATTACH]388820[/ATTACH]
I then tested the bed onto the chassis. It's tight, but it all fits together perfectly. Impressive to say how many parts are involved and how wrong it could have gone if any were slightly out of alignment. Great work Zvezda!
[ATTACH]388821[/ATTACH]
With that done I made a start on the cab, which again had lots of detail going on, even the heater vents and hosing. There'll be a few different colours going on so I built some parts up into sub assemblies and will bring them together later. I've tried for a slightly glossy textured surface on the seats to represent the cheap vinyl they were probably made from, but it doesn't show well on this picture.
[ATTACH]388822[/ATTACH]
