Zvezda 1/35 L4500R Maultier
Last evenings assembly - Whilst the chassis & subframe are really hardening off - The load bed..............................
The fit is excellent, only the sprue attachments to clean up. It's not a difficult assembly, but you have to pay close attention to the instructions - I was, and still managed to get two pieces the wrong way round! Nice wood texture on the bed & sides. I may fit the tilt to this assembly, just for ease of handling.
Paul, those photos show that thing was big! Sadly, I don't have any Pak44s in the stash
DaveComment
8,8 cm PaK 43. The only PaK 44 was the 12,8 cm, which looks similar but rather bigger; you can tell these are not that by (among other things) the pneumatic tyres and the mudguards over the wheels.Comment
I assembled the tilt - needs a bit of work on some of the joints - despite my care, I still managed to break off one of the tie downs..........
The chassis continues, sub frame added - brackets/braces of all sorts, towing hook, air reservoir, engine, exhaust pipe & silencer..............
Next will be the prop shaft and drive axle - and I still haven't reached the stage where the rear track suspension begins to be fitted.
There is still a lot of bits to be added, and those instructions need really close scrutiny. The fit so far has been excellent, and I'm really liking this build. I keep on wondering when to start the paint process, but just a few more parts................
f you have never seen this site, then it & it's sister 'Engines of the Red Army' are worth a visit https://www.o5m6.de/wehrmacht/mercedes_l4500r.php
DaveComment
Glad to see that the mojo is back Dave, looking good with so many parts assembled already:thumb2:Comment
Dave. Your tearing this one up great progress I’ve thought about getting this one done day so I’ll be seated between PaulE and Rick the mini mitesComment
Further bits added to the chassis - just a few more, and I think I can crank up the compressor & get a primer coat on.
I think this is the most complicated chassis ( in 1/35 ) I've come across. You can turn the front hubs at the moment, but as soon as you put the steering arm on, then that will lock them into position - I'm not a fan of 'working' assembles anyway, and as soon as you get a coat of paint on it will seize anyway...................
DaveComment
Plenty going on in that chassis Dave.
Not sure about the colour of the plastic though, I'd be wanting to take a bite out of it!Comment
TAttached FilesComment
