Scotties Tilly
Just one of the many reasons I dislike resin as a modeling medium. I have seen no monetary reason to chose it & the ONLY reason I do is because it's " the only table in town" for that subject. Hope it gets easier for you. PaulEComment
Very nice work Paul.
On the c/a sticking if you get some c/a primer. There are a number on the market. Prime one surface apply c/a to the other.
Problem with keeping C/A in the fridge. C/A performs by using moisture to cure.
Put it in the fridge will produce moisture when you take it out. You can put it in a plastic bag but then you have to bring it back to room temperature before taking it out of the bag..
A tip I read was to put it in a bag with rice the rice taking up moisture. Not had any problems with C/A & going off. Just make sure I put the top on immediately & tight. A good number of times I have to pierce the nozzle but i assume this does seal the liquid into the bottle. That is the criteria sealing.Comment
Good point Laurie.
Nice to see the Tilley is off and running. Some terrific detailing as always. We all suffer from the CA not sticking when it is supposed too. I usually find its when the surface is not cleaned/prepared properly or the CA has gone off. Looking forward to seeing the next updateComment
