1-87 Zis 5 Tanker for Mr. T.
  • Mini Me
    • Jun 2018
    • 10711
    #61
    No sweat Allen, I have been through a couple of thousand photos on my fav. WW2 forum......no luck. Have seen several rear end shots of Zis 5's and 6's neither of which had tail lights so I ain't going to worry about it. This puppy is getting paint tomorrow. Thanks for your help in this........much appreciated Sir.
    Rick H.
    • rtfoe
      • 9083
      #62
      Dang it Rick, you must have the same shrinking ray gun Simon had. Really nice details. :thumb2:
      • Mini Me
        • Jun 2018
        • 10711
        #63
        Thanks for the laugh Richard, I wondered how he did it. This should be the final build update before paint.......drilled out headlights located and installed, windshield wiper installed and a scratched driver's side mirror from .005 thick strip punched .048 dia. and glued to .010 dia brass rod. I think I will base coat it in black and try my hand at modulating the 4BO over the top.......in this scale it may not be noticeable, but worth a try. Rick H.Click image for larger version
ID:	1134506Click image for larger version
        • Steve Jones
          • 6615
          #64
          That's coming along at a fair old rate Rick. I have always had trouble getting hold of small chain. Is this 50 or 60 links per inch? It always seems to be in the States that you can get the really small stuff. I tried N Gauge chain but its still too big
          • Mini Me
            • Jun 2018
            • 10711
            #65
            Thanks Steve, the chain is 40 lpi. and it's almost too bulky for 1/87 scale, if you happen to know of a source for finer chain let me know. This product is produced by the Model Railroad detail manufacturer called A-Line. They also make the wipers I use for my windscreens. Thanks for dropping by.
            Rick H.
            • Steve Jones
              • 6615
              #66
              I have 48 links per inch. I brought up a whole load of it from a railway shop a few years back. He said it was using on coal wagons?? Another area I have yet to explore are ship modellers for the anchor chains. I believe they could be 50 or 60 links per inch. I just remember that when I last looked into this everything seemed to be in the USA
              • Lee Drennen
                • 7711
                #67
                Rick have you try any Ulrich models chain? I bought a bunch of it when it was available might try the web that A- line chain Joe sell is not to scale as he markets it.
                • Mini Me
                  • Jun 2018
                  • 10711
                  #68
                  Shot a base coat of Model Masters flat black....when it dries I'll top coat with Model Masters Russian Armour Green (4BO). I'm sure this will meet with Approval from the occupant of Race Towers in "Bonny" Lincs. Rick H.Click image for larger version
                  • Lee Drennen
                    • 7711
                    #69
                    Rick. Waiting for the wet stuff. The last coat of the wet stuff if you know what I mean.
                    • Mini Me
                      • Jun 2018
                      • 10711
                      #70
                      Thanks Lee, I'm surprised JR hasn't been around to tell me which shade of 4BO he thinks I should paint it! :rolling:
                      • Lee Drennen
                        • 7711
                        #71
                        Rick. Heโ€™s probably exhausted from all the Rabble heโ€™s done today
                          • 15692
                          Hi Rick
                          Great progress. Simon would approve, especially that bucket. Paint ties it all together.
                          • Mini Me
                            • Jun 2018
                            • 10711
                            #73
                            Thanks Lee and Jim, Tomorrow will be the test to see if I can modulate the green over the black with any degree of success. If not I'll just have to two coat it and call it good.Then press on with the washes, dry brushing and weathering. Cheers, Rick H.
                            • Mini Me
                              • Jun 2018
                              • 10711
                              #74
                              Tried to do a modulation on thisClick image for larger version
ID:	1134615 tiny creature.........just not enough real estate to do it properly so I two coated it in "Rooskie" green and called it good. Will give it a good 24 hours to dry and start the detail painting. Rick H.
                              • Mini Me
                                • Jun 2018
                                • 10711
                                #75
                                Thought I'd post up what I have done on the weathering so far. Still much to do but you get the idea as to where this is going.
ID:	1134699Click image for larger version
ID:	1134700Click image for larger version
ID:	1134701Click image for larger version
