Papa 695s 1/35 Mini Art Dingo Mk1
Thanks guy's, I'm glad your liking it. It's a great little kit, fitting together very nicely so far, but when putting the cab together, you put the two sides on first and it looks like its all wrong, It's not until you put the front and back parts on that you see it's ok.Comment
It also had four-wheel steering, as you can see on Ian’s model, probably partly because of the high-speed reverse. This proved dangerous, though, so the rear steering linkage was disconnected on later versions (IIRC, from the Mk. IB on) and the wheels simply fixed in the straight-ahead position — however, the whole steering mechanism was only actually deleted on the Mk. III (off the top of my head).Comment
