Here are the first four victims to my mutilations of some 1990's vintage Roskopf 1930 Mercedes Benz L2 commercial panel deliveries. They will be representative of "retired" Reichswehr Ambulances that have been pressed into Wehrmacht service as a result of wartime vehicle shortages. I have already started the conversions but have left the vehicles disassembled for the sake of starting this thread..... then give you a catch up on what has already been accomplished as we go along. Here goes......
1/87 Scale 4 of a Kind WIP
In this next installment, I have modified and extended the exhaust system using .030 dia. evergreen styrene rod with the tailpipe end drilled out .020 to give a more realistic appearance. In the next photo the rear step was made up using HO scale perforated freight car roof walk material left over from my Model Railroad days and .010X.020 evergreen strip styrene with 45 deg. chamfer at the top. and of course the rear number board was located and installed.
Rick H.Comment
OK.....so here is a little more........got a brain storm since my last post! As the lid is easily removed from these little trucks, I thought it might be fun to do a little interior detail work. made a couple of stretcher racks and found some stretchers in the stash.....also filled in the back of the cab seat to create a bulkhead between the cab and crew compartment. finally I scratched out a crew seat for the stretcher bearers/ Medical personnel to sit on while in transport. I am only doing one vehicle like this, the other three will have the lids glued down........getting close to paint. Rick H.Comment
