I'm wanting to further my practice of hairspray chipping and heavy weathering, so picked up this little kit from John as I think it should lend itself well to that. There'll also be a small base, but unless I find where the figures hat went to it may be driverless.
[ATTACH]412632[/ATTACH]
There's not much to greet you inside the box, just two crisply moulded sprue, a couple of decals, some metal foil stickers, and a fold out instruction sheet.
[ATTACH]412633[/ATTACH]
After about an hours work it was already looking like a 'dozer, with minimal clean up and everything fitting together perfectly
[ATTACH]412634[/ATTACH]
I've seen a few of these built and one thing that put me off was the massively oversized hydraulic hoses and I'd planned on replacing them with thin wire, but then I found the reference picture below. I guess Tamiya got it right after all.
[ATTACH]412635[/ATTACH]
So I carried on with the assembly, but took note of the reinforcement on the hoses and had a go at recreating it by wrapping 0.1mm copper wire around them. Not exactly authentic, but gives the impression, which is more than enough for me.
[ATTACH]412636[/ATTACH]
Everything was just snapped together at this point so I stripped it back down into sub assemblies for a coat of Mr Primer Surfacer
[ATTACH]412637[/ATTACH]
As I wanted to chip through the final colour to reveal a rusty surface it got an all over coat of Hull Red, which I then progressively lightened with red & yellow to give a variety of rusty tones. It's bit OTT as it stands, but will hopefully look okay in the end.
[ATTACH]412638[/ATTACH]
I'll let the harden up overnight and hopefully start some chipping tomorrow.
