Scotties Steyr RSO
  • scottie3158
    • 14201
    • Holbeach
    #106
    Originally posted by Graeme C.
    The cab does look lived in Paul, but then the paint on these things wasn't particularly good & wear from hob nailed boots, leather equipment with metal buckles would wear it pretty quickly in a frequently used driving cab. I like the look you've got there.
    Thanks Graeme, That was my thinking as well.
    • scottie3158
      • 14201
      • Holbeach
      #107
      I have assembled the cab but there is a lot of filler on it at the moment so will post some pics when it is all cleaned up.
      The next task is the load bed. This is where the kit really shows it's age. The easiest thing to do was remove all the detail and re do it. The wood grain was re done, then the planks re scribed. Then with a mixture of etch, pewter and punched rivets and nuts detail was redone. Not perfect by a long chalk but hopefully better than what was there.
      The tail gate got the same treatment. The kit came with a simple "eye" for the towing pintle. I have had an attempt to scratch a new one. I formed the shape of the bracket cup on a piece of styrene, then warmed up some styrene sheet and formed it over the mould. this was then drilled a pin added and secured with some scratched chain. Then added to the rest of the scratched towing hitch. I might have another go as not 100% happy with it.
      It also needs a good clean up.
      cheers
      Scottie
      • The Smythe Meister
        • Jan 2019
        • 6248
        #108
        A`noon Scottie!
        Well,to my shame,i have to admit that i`d completely missed this one until just now!:flushed: But i`ve just had a very interesting read up from the very beginning,and i have to say that your additions sure have improved the overall look,although i am surprised at how detailed this kit is considering it`s history!:thumb2: I have Italeri`s other version in the stash,(which i think Jakko mentioned a few pages back),and that isn`t as well done as your one.
        I like these quirky things,and look forward to following this build from here on in,btw..... i`m also one who likes the scuffed up look of the interior,for pretty much the same reasons that Graeme mentioned!
        Andy
        • scottie3158
          • 14201
          • Holbeach
          #109
          A`noon Scottie!
          Andy
          Andy,
          No problems at all its good to have you along. Then I can imagine it will need a lot of work. The detail can be lived with if you like a simple out of the box build but the fit and moulding is not good. Glad you like the.
          Scottie
          • minitnkr
            Charter Rabble member
            • 7532
            • Dayton, OH USA
            #110
            Love the bed work Scottie. If you redo the towing pintle consider making the cup flexible (or appear so) up & down at the mount. Pics for ref. only.
            PaulE
Name:	RSO 01 rear tow.jpg
            W/extender
              • 18901
              Coming together well Paul. My take on the cab wear is that it needs to be seen in the confines of the cab once it’s assembled so being slightly exaggerated helps.
              • scottie3158
                • 14201
                • Holbeach
                #112
                PaulE
                [ATTACH]415241[/ATTACH]
                W/extender
                [ATTACH]415242[/ATTACH]
                Paul,
                Thanks mate glad you like it. I will have to re do the pintle.
                • outrunner
                  • Apr 2019
                  • 2420
                  #113
                  Sterling job Paul, keep it up.
                  Andy.
                  • BigGreg
                    • 2182
                    #114
                    as usual you deliver stunning details... MORE MORE MOOOORE... :smiling2: :smiling2: :smiling2: :smiling2:
                    • JR
                      • May 2015
                      • 18273
                      #115
                      Love the reworked cargo deck Paul, has your hallmark of fine detail all over it.
                      • Si Benson
                        • 3572
                        #116
                        Nice tweaks Scottie :thumb2:
                        • Steve Jones
                          • 6615
                          #117
                          Lovely detailing Scottie. Well worth all the trouble
                          • GerryW
                            • Feb 2021
                            • 1757
                            #118
                            Paul,
                            Comparing the two, I'd say that the one that you've done is very close, just needs to be shaped a little with a needle file, rather than dump and start again.
                            Wish I'd got the patience to get to your standard!
                            • adt70hk
                              • Sep 2019
                              • 10409
                              #119
                              Great work again Paul.
                              ATB.
                              • scottie3158
                                • 14201
                                • Holbeach
                                #120
                                Tim, I never thought of that cheers.
                                Andy.
                                Andy cheers.
                                Greg, very kind of you.
                                John, thanks very much mate.
                                cheers Si, I'm enjoying it so far.
                                Thanks Steve glad you approve.
                                Thanks Gerry I have given it a trim and hopefully it looks a bit better now.
                                ATB.
                                cheers Andrew appreciate it.
