Tamiya BMW R75/ sidecar
Like I said there, simplest solution is to squeeze all the glue out of the tube.
Probably will squeeze it out - or let it run out, which seems to be what it wants to do! Oh well, onwards and upwards!Comment
Now got to get the rest of the painting done and get the sidecar to the right height compared to the two of them & get the arms in the right places.Comment
:smiling5:
Etched spokes are about the closest you can get, really. Unless, of course, you go and make your own from (say) very thin fishing line, or even hair … it should be doable, and strong enough to hold up the model — but rather you than meA disc of clear plastic with the spokes engraved in it might actually be a good way to do it, if the disc is clear enough and doesn’t reflect too much.
