Scotties L1500 Kfz. 70
  • scottie3158
    • 14201
    • Holbeach
    #181
    Originally posted by GerryW
    Just gobsmacked at the effects that you get - hat is well and truly off to you :thumb2:
    Gerry,
    More by luck than judgement.
    • scottie3158
      • 14201
      • Holbeach
      #182
      Added a driver and glued the top on.
      I have made a start on the gun. I have added some aiming rods to one trail arm and a shovel to the other. Am I correct in thinking the rods will be red and white bands?
      cheers
      Scottie
      • Mini Me
        • Jun 2018
        • 10711
        #183
        That is correct Scottie! If you are building an artillery piece.......I think the FK 39 is an anti tank gun captured from the Russians...... don't know if they used them or not. Rick H.
        • adt70hk
          • Sep 2019
          • 10406
          #184
          Paul
          Sorry I'm a bit late. In terms of superlatives, will 'top-notch' do?
          Love the way that has turned out.
          ATB.
          • scottie3158
            • 14201
            • Holbeach
            #185
            Cheers Rick, I guess they could just be cleaning rods then.
            • scottie3158
              • 14201
              • Holbeach
              #186
              Originally posted by adt70hk
              Paul
              ATB.
              Andrew, that will more than do thank you mate.
              • Allen Dewire
                • 4741
                • Allen
                • Bamberg
                #187
                Hi Paul,
                The 7,62 gun you have in the kit was originally a 1939 Russian 7,62 (297) field artillery piece. Loads of them were captured by the Germans and used as artillery pieces. Others were converted into Pak anti tank weapons, hence the F.K. 39 designation. These were re-bored to accept German 7,62 AT ammunition. In modifying them to the AT role, the right handwheel was moved to the left side. Now both handwheels could be operated by one person sighting the gun. A muzzlebrake was also added to these models (F.K. 39's) like in the kit....
                Aiming poles were not used on AT weapons. You could paint them wood color and leave them on the trailing arm. Aiming poles were used for artillery pieces both towed and tracked (Hummel, Wespe etc.). These were painted red and white for that purpose...HTHs and have fun moving the right handwheel (if you want to) Bro.............
                Allen
                • scottie3158
                  • 14201
                  • Holbeach
                  #188
                  Hi Paul,
                  Allen
                  Cheers Allen I think I will pass on the hand wheel. I will just paint them up as cleaning rods.
                  • Steve Jones
                    • 6615
                    #189
                    Definately cleaning rods.
                    Not to want to hijack Paul's thread but briefly what is everyones opinion of what they were made of. Metal tubes with alluminium ends or wooden with brass ends? Hopefully the answer will be both
                    • GerryW
                      • Feb 2021
                      • 1757
                      #190
                      [ATTACH=CONFIG]n1149036[/ATTACH]
                      I would say that they wouldn't use a 'hard' metal - as that could well damage the rifling & 'crown', making it less accurate
                      • scottie3158
                        • 14201
                        • Holbeach
                        #191
                        No worries about hijacking I appreciate the input. I would say wood with brass ferrules.
                        Agreed they wouldn't be hard metal and I imagine aluminium would have been to valuable for other purposes.
                        • scottie3158
                          • 14201
                          • Holbeach
                          #192
                          Hello all,
                          The gun is built, quite fiddly in places with small parts. The wheels and barrel are not glued so I can remove them for painting. Given the weather conditions I wrapped the breech and muzzle in cloth made from rizzla papers and white glue.
                          cheers
                          Scottie
                          • GerryW
                            • Feb 2021
                            • 1757
                            #193
                            Lovely work there :thumb2:
                            • Steve Jones
                              • 6615
                              #194
                              Beautiful!
                              • Mark1
                                • Apr 2021
                                • 4156
                                #195
                                I would be extremely happy if I could do half as good a job :thumb2: :thumb2:
