Icm wot 8
  • Mark1
    • Apr 2021
    • 4156
    #31
    Looking really good under primer. War paint next!
    Thanks .Yep, just waiting for some paint! Was going to do it bronze green but historically about a year out! Not usually to worried about things like that but then thought nah get the right one.
    • GerryW
      • Feb 2021
      • 1757
      #32
      Well, if you've got to get more paint, then might as well get the 'right' shade :thumb2:
      • Mark1
        • Apr 2021
        • 4156
        #33
        I brought the bronze green for this one but turns out they first produced this truck about a year after they starting using drab, I'll use the bronze green on my scammel, that fits the right age bracket!
        • Mark1
          • Apr 2021
          • 4156
          #34
          Just about all in primer now, got some steel and rust undercoat on here and there for chipping later.
          Working on the canvas top, was made in five sections and had to lose the joins so I kept brushing tamiya thin in the joins until they had melted together and then sanded, got a bit more sanding yet.Click image for larger version
ID:	1152267Click image for larger version
          • GerryW
            • Feb 2021
            • 1757
            #35
            Working on the canvas top, was made in five sections and had to lose the joins so I kept brushing tamiya thin in the joins until they had melted together and then sanded, got a bit more sanding yet.[ATTACH=CONFIG]n1152267[/ATTACH][ATTACH=CONFIG]n1152268[/ATTACH]
            As Eric used to say "Can't see the join!"
            Looking good.
            • adt70hk
              • Sep 2019
              • 10406
              #36
              Coming on nicely. Well done.
              • Mark1
                • Apr 2021
                • 4156
                #37
                Cheers guys :thumb2:
                • Mark1
                  • Apr 2021
                  • 4156
                  #38
                  Need some practice but got the chipping fluid to work for the first time :smiling: Click image for larger version
ID:	1152407Click image for larger version
                  • Mark1
                    • Apr 2021
                    • 4156
                    #39
                    Chassis and cab interior got some colour now.Click image for larger version
                    • Mark1
                      • Apr 2021
                      • 4156
                      #40
ID:	1152646Click image for larger version
                      • scottie3158
                        • 14201
                        • Holbeach
                        #41
                        Mark,
                        Apologies I have only just found this. You are making a great job of it and the wear and tear looks good. As to the engine you could argue as to it not being seen the same as tank interiors when their all buttoned up you cant see much.
                        • Mark1
                          • Apr 2021
                          • 4156
                          #42
                          No worries mate and thanks for the good comments, it's all still trial and error at the moment but I think I'm getting a bit better with each model :smiling:
                          • yak face
                            • Jun 2009
                            • 13836
                            • Tony
                            #43
                            Just had a read through mark , its looking excellent . The chipping is great , just the right amount of wear . Keep it up , cheers tony
                              • 18901
                              Looking good to me Mark.
                              • Airborne01
                                • Mar 2021
                                • 3964
                                • Steve
                                • Essex
                                #45
                                Mark,
                                Not far off persuading me to increase my stash! Looking good!
