Icm wot 8
  • Mark1
    • Apr 2021
    • 4156
    #61
    Cab almost ready for paint now,
    The two small peaks on the front of the cab are not shown in the instructions anywhere but if you hunt you'll find them on the sprues, every picture I've found online of the wot 8 has these!
    Front screens fit into separate frames so can be stuck in whenever you want really.Click image for larger version
ID:	1152914Click image for larger version
ID:	1152915Click image for larger version
ID:	1152916Click image for larger version
    • adt70hk
      • Sep 2019
      • 10409
      #62
      Mark
      Coming on very nicely indeed.
      Well done.
        • 18907
        Looking excellent now Mark, you’re making a great job on this one.
        • Mark1
          • Apr 2021
          • 4156
          #64
          Cab now in colour, that's everything painted and satin coated now,a pinwash and mattcoat when that's dry and then the final build followed by some not too heavy weathering.
          Time to crack open another one while the paints drying oh I already did!
          • Mark1
            • Apr 2021
            • 4156
            #65
ID:	1153201Click image for larger version
            • GerryW
              • Feb 2021
              • 1757
              #66
              Looking good :thumb2:
              • adt70hk
                • Sep 2019
                • 10409
                #67
                Coming on nicely!
                ATB.
                • Mark1
                  • Apr 2021
                  • 4156
                  #68
                  A couple of decals to go on and a wash on the wheels then it's getting matt coat.got some dirt and dust pigment to try out on this once its all together.Click image for larger version
ID:	1153349Click image for larger version
ID:	1153350Click image for larger version
ID:	1153351Click image for larger version
ID:	1153352Click image for larger version
                  • GerryW
                    • Feb 2021
                    • 1757
                    #69
                    Looks good, liking the dirt/dust :thumb2:
                    • Mark1
                      • Apr 2021
                      • 4156
                      #70
                      Cheers Gerry , may clean it off and start again yet, was going for a clean pin wash in the seams before using some dust and dirt pigments but as usual I rushed it and my lighting is pretty poor which dosnt help,need to look at it again in daylight!
                      • The Smythe Meister
                        • Jan 2019
                        • 6248
                        #71
                        Originally posted by Mark1
                        A couple of decals to go on and a wash on the wheels then it's getting matt coat.got some dirt and dust pigment to try out on this once its all together.[ATTACH=CONFIG]n1153349[/ATTACH][ATTACH=CONFIG]n1153350[/ATTACH][ATTACH=CONFIG]n1153351[/ATTACH][ATTACH=CONFIG]n1153352[/ATTACH][ATTACH=CONFIG]n1153353[/ATTACH]
                        That's coming along a treat Mark, cracking job so far
                        I'm watching closely, picking up ideas for when I start my one .
                        Excellent stuff mate,
                        Andy
                          • 15704
                          Hi Mark
                          It is progressing very nicely :thumb2:
                          • Mark1
                            • Apr 2021
                            • 4156
                            #73
                            That's coming along a treat Mark, cracking job so far :smiling3:
                            Andy
                            Cheers mate, quite an enjoyable build :thumb2:
                            • Mark1
                              • Apr 2021
                              • 4156
                              #74
                              Originally posted by Jim R
                              Hi Mark
                              Thanks Jim :thumb2:
                              • Mark1
                                • Apr 2021
                                • 4156
                                #75
                                A few more bits to do,matt coat, mirrors and lights, weathering wheels and tyres but you get the idea! Door handle in the pic went ping so had to improvise. And yes the front axle is wider than the rear which looks a little strange but that's how it's supposed to be. Click image for larger version
ID:	1153513Click image for larger version
