Nice result there Mark....once you have it all painted up, should look the Bomb! :thumb2: Rick H.
Soviet zil 157k
OK so I wanted to try some engine detail on this so here's my first ever bit of scratch!! Have started to make a distributor, had to put seven holes into the top of a 3mm diameter rod! I would either break drill bits or they would move about on the surface so i held a broken drill bit in pliers and heated it up with a lighter and melted the holes in, seemed to work OK so I now have 7 leads glued in,6 for plugs and 1 for the coil,the wire is 0.3 mm.[ATTACH=CONFIG]n1153573[/ATTACH]Comment
Got a bit more done, dirtied the engine a bit, cab floor and seats done and painted,bonnet put together which was fun , the two halves are supplied in the bonnet closed position in order to put in open position they have to be heated up and then folded to the right position then the two halves glued together.[ATTACH]428633[/ATTACH][ATTACH]428634[/ATTACH][ATTACH]428635[/ATTACH][ATTACH]428636[/ATTACH]Comment
