Revell/ICM 1/35 Horch 108.
    This is the 2018 Revell reboxing of the 2015 ICM original - the plastic is ICM, the rest Revell.....................
Name:	revell horch.jpg
    Sprue shots:
ID:	1155371Click image for larger version
ID:	1155370Click image for larger version
ID:	1155369Click image for larger version
ID:	1155368Click image for larger version
    Tiny decal sheet..............Click image for larger version
    Instructions - apart from the crazy Revell colour call outs, clearer than ICM instructions!
ID:	1155372Click image for larger version
    Two similar finishes.
    I bought this at a bargain price - the Revell price was much less than the ICM original. It pays to check the prices on reboxings!
    Detail pictures & comments to follow........................
    Detail shots - crisp & flash free.................
ID:	1155402Click image for larger version
ID:	1155403Click image for larger version
ID:	1155404Click image for larger version
ID:	1155397Click image for larger version
ID:	1155400Click image for larger version
ID:	1155401Click image for larger version
ID:	1155406Click image for larger version
ID:	1155407Click image for larger version
    ICM are producing some of the finest mouldings - they are producing them successfully, but it doesn't help when you have to get them off the sprue in one piece....................
    The moulding gates overlapping the part ( difficult to see how this could be overcome! )
    Tricky clean up & reinstate a hole!
    The engine grill is one of the finest moulded pieces I've seen! ( pic 5 ) With this delicacy there's little need for any PE detail sets. The only thing that maybe be improved is some resin tyre replacements, I'm not wildly enthusiastic about the vinyls
    Construction will start soon!
    • adt70hk
      • Sep 2019
      • 10415
      Looks very nice indeed Dave.
      ATB.
        Assembly begins - a bit fiddly, and rather complicated - its a 4 wheel drive. independent suspension...............
        Careful cutting from the sprue is essential, and close study of the instructions! - many similar parts to get in the right place, which will turn round & bite you if you don't pay attention
        • RonGlass
          • 801
          I'm glad you're building this Dave, I have the ICM kit cued very soon myself. I've grabbed one of these comfy chairs up front, the folding one that Paul furnished over at his build is like sitting in a church pew.
            A bit more work on the chassis - you have to be attentive to the part numbers here!
            Here's something that is a real pain - two thin bars/tubes (?) that run between the front & back hubs ( central tyre pressure system? )
            It took me quiye a while, but I got them off in one piece!
            Having done that - I think I'm going to replace these with wire - the clean up on the parts is virtually impossible, and would severely try my patience!
            I have to assemble the engine, but that's really just to fill a hole & locate the exhaust - the bonnet will be tightly shut..........
            It doesn't help that the spring on my extra fine sprue cutters broke - it's still useable, but a nuisance!
            • outrunner
              • Apr 2019
              • 2420
              I know how you feel with the really fine parts Dave, since I got some Dspiae nippers the world looks much better, hardly any clean up and tiny parts just fall of the sprue.
              Andy.
              • Mini Me
                • Jun 2018
                • 10711
                Nice progress so far Dave, looking on with interest. Rick H.
                  • 15722
                  Hi Dave
                  The kit looks nice but the sprue shots show a lot of rather small, delicate parts. Chassis looks good. I'm sure you're right to replace that pipe/tube bit with wire - clean up would indeed be very hard.
                    The chassis is compete & ready for priming. It's very detailed & loads of tiny parts - luckily the instructions are clear ( and much bigger than the ICM originals )
ID:	1155538Click image for larger version
                    I'd say that was the back of the difficult stuff broken, the parts get bigger...........................
                    edit - just realised I've left off the prop shafts! - doh!
                    • scottie3158
                      • 14208
                      • Holbeach
                      Dave,
                      Nicely done the pipe replacements look good.
                      • Mini Me
                        • Jun 2018
                        • 10711
                        No "propping" about for you Dave....
                          He he - I've looked forward in the instructions & the prop shaft isn't fitted until the bodywork is joined to the chassis a lot further on - there's some sort of brake (?) on the propshaft which mounts onto the body. - I really thought I'd missed that out, but nope!
                          • Mini Me
                            • Jun 2018
                            • 10711
                            Nice recovery there.....press on.
                            Rick H.
                              Primed & did a little detail painting on the chassis - I used masking fluid on the wheel hubs, so I won't have to scrape the paint off................
                              The body assembly couldn't be easier, just hold the parts together & apply a drop of TET, no hassle, no straining of parts. My only worry is when to start painting................
