The instructions recommend making a spacer of a certain thickness from some spare material, but don’t tell you how to line everything up correctly. The way I did it wasn’t perfect, but far better than trying to do it by eye. At first I tried lining them up with just the ruler on the outside, but the doesn’t work because there is no positive location for the bogies at all — you have to slip the outer end of the leaf spring through a gap in the bogie and … that’s it. The bogie can move all the way along the spring until it hits the etched bit above it, and there is nothing to indicate how far along it should go. A quick rummage produced that square-handled sculpting tool that I could use to push the wheels outward with, which helped a lot.
M29C Water Weasel
To strengthen the suspension, I glued a piece of plastic strip behind the tops of the bogies and then added supports between the strip and the hull:
[ATTACH]434489[/ATTACH]
All of this should end up hidden behind the side skirts — or so I hope
I also added the idler wheel mounts. How these fit is not very clear from the instructions, nor from the pictures I took of the real vehicle, so for anyone else attempting this in future, here is how they should go:
[ATTACH]434490[/ATTACH]
And then with the idler wheels on as well:
[ATTACH]434491[/ATTACH]
To attach both the idler mounts and the wheels themselves, I drilled holes and inserted plastic rod as pins, else it would have been butt joins all around, which are not overly strong.Comment
The tracks are great fun too. They come as a short and a long length for each side, the idea being that the short one goes on top while the long length curves around the idler and sprocket wheels. Since the skirts will obscure the top run, I only used the long part, using a hair dryer to soften one end of it and bending it around the jig provided in the kit. After that I repeated with the other end, then dry-fitted and found I had to bend some more but now around the wheels — which the kit instructions also point out, by the way.
After that there was much fun removing the tiny guide horns from their sprues, cleaning them up and glueing them to the track. Here’s one with and one without:
[ATTACH]434540[/ATTACH]
The easiest way to glue them is to out a drop of superglue onto something where it will keep for a bit (I used baking paper), dip the link into it with non-pointed tweezers and then sticking it onto the track. If you use pointed tweezers, you’ll find them poking through the holes in the track, making it had to remove the tweezers without taking the guide horn along (guess how I know). Switching to tweezers with rounded jaws made the job much easier.
And then, when I had two done, I of course went to install them on the hull. That again isn’t a quick or easy job, either …
[ATTACH]434541[/ATTACH]
I ended up using three self-locking tweezers to clamp the roadwheels to the lower run of track, then flowing superglue between wheels and track on both sides using a sharpened cocktail stick. I left the front and last roadwheels without glue, and also the sprocket and idler, so I can still manipulate the track a bit after this dries, because neither side really fits as well as I would like yet.Comment
I wishthe majority of the kit’s parts still remain to be fitted, and most of them are tiny (and bigger) etched brass …
I just wish it would go a bit faster, really … But I have to finish the suspension before I can fit the upper hull, and it turns out the suspension can only be worked on one side at a time, so that very much limits the rate at which this model can proceed. Sure, it’s superglue, so it sets fairly quickly — but it would be better if I could do both sides and leave them to dry overnightComment
That’s true, but I’m going rather slower than I would like. This has a number of reasons, one of them being I have other stuff to work on that’s more important than this model, but also that I’m not overly enjoying this one so I don’t feel like working on itHopefully that should improve once I get past this suspension …
ThanksComment
I take it that’s British understatement …I said it before, but the text “suitable for advanced modellers” on the box front is not an exaggeration. Don’t buy this if you have a few Tamiya kits under your belt and think you’re a skilled modeller now
But I’m glad to report real progress being made on the suspension now:
[ATTACH]434610[/ATTACH]
I glued the other track on like the first, though now by putting glue on the undersides of the roadwheels first rather than flowing it in there after the track was on. I felt confident doing this because of having gotten a feel for how it fits when I installed the other track.
Next, once that had dried, I took a soldering iron and used it to carefully heat the track only where I needed to bend it some more, by holding the model over the iron until the track was soft enough. Then I bent it into shape, held it until it cooled, and flowed more superglue between wheel and track using a cocktail stick again.
All this appears to have worked well. I’ll leave it to dry overnight before giving it a coat of black primer, to make sure no resin will remain visible there after painting the whole model.Comment
It definitely is. The build is slightly stalled for now, as I have some other things (non-modelling) to finish over the next few days, but hopefully I can then continue on this model. And if I’m lucky with a bit more speed than until now, despite the fiddlinessComment
