Master Box 1/35 Typ 170 V Tourenwagen
    My Barchino will shortly be finished & I've been pondering my next build, and I've decided on this...............
Name:	Master Box 170 V.jpg
    Not the most inspiring of boxarts! - It is of course a Mercedes-Benz, but obviously trade marks get in the way of naming it!
    I've had this for quite a time & I've been hesitant to start it, as my track record with Master Box is poor! I've had major problems with fit & poor instructions ( mostly figures ), and my completion rate is low! Reading reviews on this model is generally good, but it seems that vague instructions are also present ( or not present! ). Having made quite a few cars recently, I think now is the time to have a go at this.
    I'll put some sprue shots & detail shots up tomorrow.........................
    • 18901
    I built this a long time ago, before joining Internet forums. I remember it fitting quite well but the plastic was a little brittle. The winter radiator cover and closed in windows are a nice touch and the engine detail was pretty good..
      Sprue Shots.......................
ID:	1157795Click image for larger version
ID:	1157796Click image for larger version
ID:	1157797Click image for larger version
      Parts look pretty crisp, no flash - plastic feels a little soft.
      A few detail shots
      Kar 98K rifles
      Tubular steel chassis
      Double leaf springs
      Radiator ( no winter coat option )
      Small parts look well moulded - although 7 ingates on the bumper seems excessive.
      The colour call outs - all overall Panzergrau! No information on the decals - although 9 pairs of number plates are supplied, Wehrmacht, Luftwaffe, Field Police & Navy. I believe, as these were second line vehicles, camouflage wasn't applied.
      Instructions - well, they are on 1 1/2 sides of a multi folded A2 sheet - the other bit is model tips in several languages. Quite the largest instructions I've seen for a small model!
      I'm not keen on these render style guides, unless the printing is very good ( it's not! ). You lose detail in the half-tones, due to the printing process. Simple ISO line diagrams are much clearer.
      Looks OK so far, the crunch will come in actually fitting bits together...................
        • 15679
        Hi Dave
        Sprue shots look to show decent detail. Personally I'm not a fan of those rubbery tyres. Roof up or down?
          Originally posted by Jim R
          Hi Dave
          Jim,
          hood down, I don't want to spend time on the interior & then hide it.....................
          I'm not a fan of the vinyl tyres, either, but I'll have to make the best of them!
            • 18901
            Sorry Dave. Led you astray a bit there. Just looked….I made the 170 VK….
            Looks very similar though….
              Tim,
              I wondered about that - the VK is the 2-door version, odd, the vast majority of the parts must be the same, I wonder why they dropped the thermal blanket for the rad?
              • Allen Dewire
                • 4741
                • Allen
                • Bamberg
                The 170 VK kit came out a year after the one you're doing Dave. It's 4 door and has the winter set up for the windows and radiator....
                I guess you have to wonder if it had a good heater in it though..........
                • JR
                  • May 2015
                  • 18273
                  Just imagine it with four figures, driver plus
                  3 officers!
                  Are you going to have any Dave ?
                    3 officers!
                    John,
                    I have some German drivers, somewhere - I'll look them out. I have a visualisation of the car, driven by an officer, with the back seat filled with crates of purloined French wine & champagne!........................
                    But then again, maybe not! :tongue-out2:
                      I’m picturing a little diorama representing the opening scenes of Das Boot … I mean, the Kaleu and Werner are obviously driving a Mercedes there
                        Originally posted by Jakko
                        I’m picturing a little diorama representing the opening scenes of Das Boot … I mean, the Kaleu and Werner are obviously driving a Mercedes there :smiling3:
                        Hmm,
                        where do I get a dozen drunken sailors? and they'd need modifying...........................
                        Dave :smiling4:
                        • RonGlass
                          • 801
                          :smiling6:
                            Finally got to the bench! A hours or so has produced this:
                            The tiny engine has lo less than 16 parts - the chassis is a single moulding - a touch of over engineering, I think.
                            One thing that I had not picked up on is that the parts are not numbered on the sprues - it means constantly referring back to the sprue layout pics - which on an A2 sheet is a real pain! Each sprue starts at one ie A1, B1, C1, etc, so there are multiple parts called 8 foe example. The halftone instructions aren't printed at a good enough resolution to be clear.
                            Apart from that the parts are pretty clean, and no fit problems so far.....................
                              • 18901
                              I’d forgotten the lack of sprue labels…..engine is a lot of parts but does look good when it’s done….
