IBG Scammel pioneer
    • 18931
    Lovely work. There is plenty of detail here to take your eye isn’t there.
    • Mark1
      • Apr 2021
      • 4156
      #17
      Thanks Tim, it is a nicely detailed kit but as with all these chassis and engines it will soon be hidden away never to be seen again!
      • adt70hk
        • Sep 2019
        • 10426
        #18
        Mark
        Coming on very nicely.
        As you say, is a shame that a lot of it will be hidden away, never to be seen again.
        ATB.
          This is why I usually dry-fit things like the cab and bonnet to see which parts underneath them can go straight into the spares box With a lot of soft skins you can leave the entire engine out, or only fit the sump, and nobody will be the wiser.
            • 15737
            Hi Mark
            As Tim says there is some lovely detail. Just hope that quite a lot can still be seen on the completed model. Your build is very neat and clean :thumb2:
            • Mark1
              • Apr 2021
              • 4156
              #21
              Originally posted by adt70hk
              Mark
              ATB.
              Thanks Andrew.
              • Mark1
                • Apr 2021
                • 4156
                #22
                Originally posted by Jakko
                This is why I usually dry-fit things like the cab and bonnet to see which parts underneath them can go straight into the spares box :smiling3: With a lot of soft skins you can leave the entire engine out, or only fit the sump, and nobody will be the wiser.
                Wasn't much I could leave of this,was only 15/20 minute build anyway won't be paint detailing.
                • Mark1
                  • Apr 2021
                  • 4156
                  #23
                  Originally posted by Jim R
                  Hi Mark
                  Thanks Jim got a bit of clean up to do but won't be to fussy unless I model it upside down in a ditch lol.
                  • Mark1
                    • Apr 2021
                    • 4156
                    #24
                    I have got the truck bed and crane.under way have some pe to add.to the crane and this nice little name plate for the winch.Click image for larger version
ID:	1159388Click image for larger version
ID:	1159389Click image for larger version
                    • minitnkr
                      Charter Rabble member
                      • 7551
                      • Dayton, OH USA
                      #25
                      Shaping up nicely.
                      • adt70hk
                        • Sep 2019
                        • 10426
                        #26
                        Looking very good indeed.
                        Well done.
                        • Airborne01
                          • Mar 2021
                          • 4001
                          • Steve
                          • Essex
                          #27
                          Mark,
                          That's looking very good! I'm now tempted, and I can resist everything except temptation!
                          Steve :thumb2:
                            • 18931
                            Lovely work. The etched nameplate is a nice touch.
                            • Mark1
                              • Apr 2021
                              • 4156
                              #29
                              Originally posted by minitnkr
                              Shaping up nicely.
                              Well done.
                              Mark,
                              Steve :thumb2:
                              Thanks chaps :thumb2:
                                Originally posted by Mark1
                                I have got the truck bed and crane.under way have some pe to add.to the crane and this nice little name plate for the winch.[ATTACH=CONFIG]n1159388[/ATTACH][ATTACH=CONFIG]n1159389[/ATTACH][ATTACH=CONFIG]n1159390[/ATTACH]
                                Oh! I just noticed something I picked up on another forum recently when someone else built one of these: Is the central part of that crane boom fixed in place yet, or still movable? Because it should sit parallel with the two side booms, not between them (like, I gather, this kit almost wants you to put it):
                                [ATTACH]433764[/ATTACH]
