Scotties Sd.Kfz. 10/5
  • scottie3158
    • 14243
    • Holbeach
    Hello All,
    This is next on the bench. Revells offering of the Sd.Kfz.10/5. I was after the Italeri offering but after checking on scalemates its the same kit. The box is the typical end open box from Revell which I personally don't like. The kit also came with the Eduard etch and a Passion models replacement barrel.
    Just a quick look at the sprues which are moulded in light Tan and appear to be fairly crisp and free from flash.
    I also got this to go with it.
    Cheers Scottie
  • scottie3158
    • 14243
    • Holbeach
    I have made a start with the cab. This was very over simplified so with a mixture of the PE and a lot of scratching I came up with this.
    cheers
    Scottie
      • 15799
      Hi Scottie
      A nice choice. I have often wondered why half-tracks seem to have only been manufactured around the 1940s. Was there some flaw with them?
      I like the trailer - added interest.
      Great improvement to the cab.
      • adt70hk
        • Sep 2019
        • 10438
        Nice start Paul.
        ATB.
          • 18944
          Good start and already showing the usual Scottie touches :thumb2:
          Class
          • minitnkr
            • 7573
            • Dayton, OH USA
            Great details!
            All the disadvantages of tracked & wheeled vehicles.
            • Steve Jones
              • 6615
              Off to a great start mate. There are stacks of research stuff on the tinternet but if you need anything let me know. Good luck my friend
              • scottie3158
                • 14243
                • Holbeach
                Originally posted by Jim R
                Hi Scottie
                Thanks Jim. True they didn't appear after the war to my knowledge. Most of the vehicles seem to pull these, and the box contains two trailers so I have one for another time.
                Originally posted by adt70hk
                Nice start Paul.
                ATB.
                Cheers Andrew.
                Class
                Cheers Tim not perfect by a long shot but it looks a bit busier.
                Originally posted by minitnkr
                Great details!
                I can't see the advantage of a half track unless cheaper to manufacture?
                [/QUOTE]
                Thanks Steve I have some good pictures from prime portal but trying to fine some better ones of the front axle.
                • The Smythe Meister
                  • Jan 2019
                  • 6248
                  Nice choice Scottie Dawg :thumb2: ,
                  Needless to say i`m definitely "In" for the duration mate.
                  As has been said,you`re off to a cracking start already ,
                  Andy
                  • Mini Me
                    • Jun 2018
                    • 10711
                    Nice choice and off to a great start Scottie. :thumb2: Rick H.
                    • Steve Jones
                      • 6615
                      Is it the one where the leaf spring goes across the front of the axle??
                        Cost and benefit. A halftrack costs almost the same as a full-tracked vehicle to build and maintain, but it’s less capable cross-country. Once all-wheel drive had been perfected, it made more sense to build 4×4, 6×6 etc. vehicles instead of halftracks for all-terrain cargo transport, because they were far cheaper, and go to full-tracked vehicles for APCs because they’re far more capable at not that much greater expense.
                          • 15799
                          Thanks Jakko
                          Obvious really. Half-tracks always look so capable.
                          • scottie3158
                            • 14243
                            • Holbeach
                            Yes mate that's the one
                            • Steve Jones
                              • 6615
                              I have dropboxed a load of stuff for you. You should have it by now???
