My interest in vehicles used in my particular part of the world is probably fairly well-known here by now
So, when I came across this picture while doing research for my book that was published last year, I thought it would make a very interesting model:
(Anefo, via Wikimedia Commons)
This is on Markt square in the town of Middelburg, very recognisable by its 15th-century town hall, which was being restored even during the war following the city fire of 17 May 1940 in which it burned out completely.
Here’s what this area looks like today — that link takes you to as close as you can get on Google Streetview to the spot where the above photo was taken. However, the 1990s-built flower stall is in the way a bit for seeing the town hall and the half-track’s location.
Another picture in which the same Sd.Kfz. 7 appears, is this one, taken from slightly more to the right (=east):
(Anefo via Wikimedia Commons)
The vehicle is a late-model Mittlerer Zugkraftwagen 8 to. Sd.Kfz. 7, “Medium Tractor, 8-tonne”. The late version of this differed from the early one by having a wooden lorry-type load bed rather than two rows of forward-facing benches; there were an ammunition stowage box and foreward/rear, back-to-back benches in the load bed. However, these have been removed from the vehicle in the photo, as have the engine compartment covers, windscreen, tilt hoops, front tyres and even the outer row of roadwheels. I’m not sure, but I think the cylinder head has also been taken off the engine, as have various other bits in the engine compartment, and of course everything that was loose, is gone.
Model-wise, you can pick Dragon or Trumpeter to build this vehicle, but I bought the former:
I’m not an expert on these vehicles, but a little reading makes me believe the Dragon kit is a little more accurate, if probably trickier to build.
Here is what you get inside the box:
[ATTACH]442357[/ATTACH][ATTACH]442358[/ATTACH][ATTACH]442359[/ATTACH][ATTACH]442360[/ATTACH][ATTACH]442361[/ATTACH][ATTACH]442362[/ATTACH][ATTACH]442363[/ATTACH]
Much of this is superfluous anyway, being parts for other Sd.Kfz. 7 variants, and I can discard a good deal more bits on top of that in order to build it as per the photo
I also got this replacement grill from Panzer Art:
[ATTACH]442364[/ATTACH]
The main advantage is having open louvres, which might be tricky to achieve with the Dragon part that has them moulded with a flat plate behind them.
Now to study how best to start building this …
