Sd.Kfz. 7 half-track, post-war
    Before adding the camouflage, I had to mask the engine bay. I started looking at how to do that with masking tape, when I suddenly had the brainwave of just using the kit’s engine panels, propped up with some Blu-Tack:
    [ATTACH]445737[/ATTACH]
    The grill is also still loose, as you can tell by the Blu-Tack behind it too, and then I just added the bonnet with some tape:
    [ATTACH]445738[/ATTACH]
    The tape on the sides of the cab is because if you look at the photos of the real thing, you can work out that it had its camouflage sprayed while the tilt over the cab was on
    All that remained then was to spray the camouflage, copying it as well as possible from the photos of the real vehicle:
    [ATTACH]445739[/ATTACH]
    On the right side of the vehicle, it’s nearly all speculative, of course, because of not having any pictures of that side available:
    [ATTACH]445740[/ATTACH]
    This used Vallejo 71.043 US Olive Drab and 71.041 RAL 8017 Rotbraun, though note that this particular bottle of the OD is far too green for American vehicles, but probably right for German ones:
    Here, I used the one on the left, while for American vehicles I would take the other one.
    In the load bed and the cab, I used the Steve Zaloga method of spraying random blobs of a paler colour to break up monotony of the large dark yellow areas.
    [ATTACH]445741[/ATTACH]
    • Mini Me
      • Jun 2018
      • 10711
      #167
      Brilliant masking of the engine compartment......almost as if it was made for it!! :tongue-out3: :tongue-out::tongue-out2::thumb2:
        You’d almost think that, wouldn’t you?
        • adt70hk
          • Sep 2019
          • 10415
          #169
          Coming on nicely Jakko...... An inspired use of the vehicles parts!!
            Though I’m not really a fan of pre-mixed washes, I decided to use a Mig one intended for dark yellow on this model. I did some tests first, on the underside of the load bed and the inside of the chassis below it because those will be largely out of sight, and I concluded that this Mig wash needs to be thinned about 1:1 with water if you’re going to use it as a simple, all-over wash. So I did, by putting some on the model with my brush, then dipping it in water to add about the same amount of that and smearing it out.
            [ATTACH]445855[/ATTACH][ATTACH]445856[/ATTACH]
            On the vertical surfaces I used a large, wide brush to create vertical strokes after the wash had dried a it but was still wet. This went reasonably well, but the wash changes its intensity to some degree as it dries, I found afterward. It also turns the model darker, as I had expected, but what I hadn’t anticipated was that it makes it much more matt as well.
            Anyway, to try and lighten the model’s shade a bit again, I drybrushed the dark yellow parts with the Mr. Hobby paint I had used for the main coat. After that, I also drybrushed those same parts with an old Rackham colour called Parchment Yellow, both to lighten the model and highlight the details:
            [ATTACH]445857[/ATTACH]
            You may also spot that I painted part of the upper surface of the front of the cab with dark yellow, because I suddenly realised I had forgotten that the windshield would almost certainly have been on the vehicle when it was sprayed. So before the wash, I taped off the front half and painted the rear dark yellow with a brush.
            • RonGlass
              • 801
              #171
              [ATTACH=CONFIG]n[/ATTACH][ATTACH=CONFIG]n[/ATTACH]
              On the vertical surfaces I used a large, wide brush to create vertical strokes after the wash had dried a it but was still wet. This went reasonably well, but the wash changes its intensity to some degree as it dries, I found afterward. It also turns the model darker, as I had expected, but what I hadn’t anticipated wad that it makes it much more matt as well.
              You may also spot that I painted part of the upper surface of the front of the cab with dark yellow, because I suddenly realised I had forgotten that the windshield would have been on the vehicle when it was sprayed. So before the wash, I taped off the front half and painted the rear dark yellow with a brush.
              Good thinking about the top of that cowl Jakko, I probably would have missed that
                So had I
                  • 15722
                  Hi Jakko
                  Masking with the kit parts was a real lightbulb moment. Paintwork looking good. I've never had much luck with water based washes but yours looks good.
                    I was looking at the model, holding masking tape in my hand and wondering how I was ever going to neatly tape up the line along the bottom where the camouflage should stop … I wasn’t going to add the bonnet, until I noticed in the photo of the real vehicle that the small vertical front part of the cab was almost entirely painted with one of the camouflage colours.
                    My main problem with Vallejo acrylics is how to clean them out of my airbrush, since water doesn’t really work to clean them out and they don’t want to dissolve in cellulose thinner at all
                    • Mark1
                      • Apr 2021
                      • 4156
                      #175
                      I use the vallejo AB cleaner, seems to do the job pretty well.
                      • RonGlass
                        • 801
                        #176
                        My main problem with Vallejo acrylics is how to clean them out of my airbrush, since water doesn’t really work to clean them out and they don’t want to dissolve in cellulose thinner at all :smiling3:
                        Ive been using general-purpose kitchen countertop spray cleaner (Lysol, 409, etc) for about 5 years now with no problems.
                          • 18912
                          VJ airbrush cleaner or suchlike works just fine for me as well, as does windex window cleaner Jakko.
                            I may have to investigate and find something like that … I’ve tried water, isopropanol and cellulose thinners, and oddly, water is the only one that sort of works. But even then I still need to scrub the airbrush clean with a rag on a cocktail stick to get it all out.
                              • 18912
                              Amazed that cellulose thinners doesn’t move it to be honest Jakko. It seems to strip anything it touches….Windex is very good, actually. It’s also good for stripping models if you need to refinish things.
                                Exactly, that’s why I tried it, but Vallejo seems to be impervious to it: the thinner just sits on top of the paint that’s in the airbrush.
