Thanks
I try to avoid overall coats of varnish, because of all the things that can go wrong with them … The model is matt enough for my taste as it is — it looks slightly glossier in the pictures than in the flesh, probably because of the lights I use.
By now I’ve fitted the exhaust pipe:
[ATTACH]446249[/ATTACH]
Dragon’s way of fitting it is just plain stupid. It’s split into two parts: the upper half of the muffler with one of the pipes attached, and the lower half with the other pipe. Dragon wants you to put the upper half into the chassis and then add the lower half. This means that you either need to paint it after installation or will have to deal with seams on the muffler’s sides after it’s gone into the chassis. I wanted to paint it off the model, so I put it together and then cut the front pipe off, drilling holes so I could insert a pin into the rear end of the pipe. That let me fit the whole muffler and rear exhaust pipe into the chassis, and only then insert the front pipe.
At the front, I put some matt varnish over the license plates, both to get rid of any shine and to glue the numbers down better. I next put a little grime on them by drybrushing a little bit over them, and installed the headlamp glass:
[ATTACH]446250[/ATTACH]
The engine and exhaust manifold are also in, but still loose. I drybrushed the engine with progressively lighter shades of dark to medium grey, to bring out detail and add highlights, but that’s better visible in this picture:
[ATTACH]446251[/ATTACH]
I also repainted some details, as they had gotten washed out by the drybrushing.
