Oh, I will — it’s just that I’m getting mildly frustrated by having to stop and think some more about what I thought I had figured out and just needed to do. But this is par for the course for models I build
To be honest: I’m building a semi-wreck, so it’s bound to be slightly complicated
However, trying to find out how the supports for the load bed should be, I decided to look at the instructions for the Trumpeter kit of this vehicle, and I discovered I would have been better off buying that one instead. It has the correct load bed supports, narrower spare wheel carrier, bolts on the underside that are missing on Dragon’s kit, and more … The only thing Dragon appears to have going for it, is tracks that are easier to clean up and assemble. But I’ll stick with what I have, I guess.
I came across it at a model show a decade ago or so, and it looked so useful that I bought it there and then. I’ve never regretted it. It may or may not be obvious in the photo, but it clamps onto the workbench: there is a screw handle underneath so it can be tightened to almost any thickness of work surface. The handle you can see sticking out is the lock for the position: release that and you can tilt the upper part as needed.
