Construction starts, not with the first stages:
I'm leaving the engine out, you can't see it, it has no cooling system & no transfer box to power the bucket - and doesn't provide any locations for further bits, a waste of plastic............
The chassis has all the bits added, primed & basecoated ( dark patches are undried paint - all bit fitted well, no problems.
Wheels, idlers & sprockets assembled, primed & basecoated
The road wheel tyres were primed & sprayed rubber black
My usual method of rolling a piece of paper & threading the tyres over - makes it easy to handle & spray.
Had a calamity - the quick release coupling failed between hose & airbrush - it uncoupled OK, but wouldn't shut the air off & I couldn't reconnect the airbrush again. A nuisance, I had to drain the air-tank, remove the coupling from the hose & because my airbrushes have the quick release spigot fitted remove those as well, before continuing the session. Not disastrous, but very annoying - I managed to get paint all over my hands & jeans..............
