Scotties big Zundapp
  • scottie3158
    • 14199
    • Holbeach
    #196
    Originally posted by outrunner
    Ian beat me to it, I was just thinking that is a very nice boxer engine scottie.
    Andy.
    Cheers Andy.
    • Graeme C.
      • 1597
      • Graeme
      • UK
      #197
      The engine looks great Paul, oil & dirt collecting in the recesses, a bit confused by 'fine detailing will follow' though! Looks perfect to me as it is.
      • scottie3158
        • 14199
        • Holbeach
        #198
        Graeme thanks mate. There is a little to do.
        • Scratchbuilder
          • Jul 2022
          • 2689
          #199
          Just caught up again, and the workmanship is first class as always. Cannot add more to the comments as it has all been said.
          • The Smythe Meister
            • Jan 2019
            • 6248
            #200
            All been said by the guys already....
            .... all I can add is that,if you showed one of those pics on it's own to someone, they'd think it was the real thing!!
            Excellent stuff mate.
            • scottie3158
              • 14199
              • Holbeach
              #201
              Cheers Mike, I have to try and keep up.
              Excellent stuff mate. :smiling3:
              Andy many thanks for the kind comment.
              • adt70hk
                • Sep 2019
                • 10400
                #202
                Following another very prompt delivery from John in the shop my paint arrived. The engine following a black pre shade received a coat of Tamyia Aluminium. This was followed with a very thinned down coat of Valleyo smoke. The details such as the HT leads and spark plug caps, battery and tray were then picked out. Then an oil wash with diluted W&N black was applied to pick out the details.
                [ATTACH=CONFIG]n1191081[/ATTACH]
                [ATTACH=CONFIG]n1191082[/ATTACH]
                [ATTACH=CONFIG]n1191083[/ATTACH]
                [ATTACH=CONFIG]n1191084[/ATTACH]
                Final detailing will follow when this has dried thoroughly.
                Next the sidecar gearbox was treated the same way as the engine with the exception that Tamyia dark yellow was used as well.
                [ATTACH=CONFIG]n1191085[/ATTACH]
                [ATTACH=CONFIG]n1191086[/ATTACH]
                The frame halves have also received a coat of flat yellow ready for assembly.
                cheers
                Scottie
                Scottie,
                I don't know motorbike engines in the slightest..... But to my eye that looks like the real thing.
                Very well done indeed!!!
                ATB.
                • scottie3158
                  • 14199
                  • Holbeach
                  #203
                  Originally posted by adt70hk
                  Scottie,
                  ATB.
                  Thanks mate appreciate the comment glad it passes muster.
                    • 18890
                    Looks great to me Scottie. As the others have said, it looks real :thumb2:
                    Oil washes do work well if you have the patience don’t they. I find that leaching a little of the oil out on a scrap of cardboard first helps them dry flat as well……
                    • scottie3158
                      • 14199
                      • Holbeach
                      #205
                      Hi Tim thanks mate. I do that with the oils as well . On this occasion not overly worried as It is all going to get a flat coat.
                      • scottie3158
                        • 14199
                        • Holbeach
                        #206
                        Rear wheel, mudguard and pillion seat fitted. My reference pics also show the plates fitted so fabricated them out of some evergreen with punched washers and bolts.
                        The seat is sprung but sits very high so I will glue it at the right height later.
                        Next following the fine Jerry cans from Ben aka Yambam26 I have started fabricating the can holder. I have used 0.5 copper sheet cut into strips these were then soldered together. I used the solder paste for the first time on this and I am very impressed.
                        There is still a lot of cleaning up to do and make the locking bar with its hinge.
                        cheers for looking
                        Scottie
                          • 15653
                          Good work Scottie. Some neat soldering on that frame. On something like that I find that soldering one joint can sometimes un-solder the already done nearby joint!
                          • scottie3158
                            • 14199
                            • Holbeach
                            #208
                            Jim,
                            That is one really good thing about the paste I used it flow beautifully with the minimum of heat so the surrounding metal doesn't get to hot plus I use a gas torch with a very pointed flame so the heat goes where I want it.
                            • Mark1
                              • Apr 2021
                              • 4156
                              #209
                              Taking shape very nicely :thumb2:
                                • 18890
                                Jim,
                                Nice soldering Scottie. Just for info, you can also clip pads of wet tissue or soaked natural sponge on the early joints so they don’t heat up as fast as the one being made. Clip them on using aluminium hair grips so they don’t get soldered to the workpiece in error. Watch out for solder paste/cream, I found it goes solid quite quickly and becomes unusable.
