Scotties big Zundapp
Ha Ha thanks Jack, if I can do it so can everyone.
Cheers Steve Hae a guid day.
Rick, glad your not leaving mate you will have to wait anyway I can find the key to open it again :tongue-out2::tongue-out2:Comment
A little bit late to answer Jim's question as I had already done it. But I replaced the bikes rear mudguard support with a fabricated one. The kit one would have cleaned up ok but it is nothing like the one in my reference pics.
The kit one;
My replacement. 1.2mm wire formed into shape the ends were then flattened and filed to shape. A web was added either side from 0.75 evergreen sheet and a 1.25 nut punched from the same sheet. before the plastic was added I made the fixing bracket from some 0.5 copper sheet and soldered it in place. It still needs a bit of tidying up as the picture has shown me.
Thanks for following along and the positive comments
ScottieComment
Hmmmm, knit one, perl two. knit one, perl two. knit one..........Damn, where was I???.............Life's to short to be a sheep...Comment
Welcome aboard mate it's good to have you along. I better make sure I get things right having a bike builder looking in.Comment
simonWhy is common sense not so common?Comment
I can't say its imagination I just try to add what I can see in my reference pictures and knowledge of how things should be from being an engineer. You should try it, it is a lot easier than you think.
Thank you Mick but you can put the cylinders away for now :smiling:Comment
I would say not for a mild steel system operating in very challenging conditions. I would expect some heat blueing on the outlet exhaust downpipes though.Comment
I agree with Tim, the exhaust is probably not over-rusted if the bike has been used for a fair while. Maybe a bit dark in colour — I remember the rusted parts of the exhaust of my moped 30+ years ago being more of a tan-grey, but other than that, IMHO it looks very convincing.Comment
