Scotties big Zundapp
I had some fun today the rod I was waiting for has turned up so the first linkage was replaced. As far as I can make out this lever could engage/disengage the drive to the side car all though I could be wrong.
Firstly the kit part
Although not exactly bad it does lack definition so Scratched it had to be. So using brass rod. copper sheet punched and drilled nuts and punched details and part of the original linkage I came up with this.
then a picture of each end. The arm is not glued in place yet to allow me to position it correctly.
next the gear selector but that will be another day.
cheers
ScottieComment
Incidentally, never build a BMW R 75 or Zündapp KS 750 as a solo machine without a sidecar as if they were also used that way (both Tamiya and Italeri released 1:35 scale sets like that in the 70s). These bikes were designed from the ground up to have the sidecar, and if the sidecar is removed, the differential lock is too weak for prolonged use. With the lock disengaged, you won’t be going anywhere, of course: all power will go to the free end of the differential, and the bike’s rear wheel then doesn’t turn at all. Enterprising people (after the war) built a plate to stick to the outside of the differential so the bike could be ridden without a sidecar and without destroying the lock, though.Comment
I hoped you wouldn't notice
From looking at a few photos, the rear lever seems to be on the differential, and IIRC, it’s to lock the differential so power always goes to both rear wheels.
Thanks, that makes perfect sense having a diff lock.
Thank you mate. I have a razor saw which I use one the tube. For wire I have some side cutters and nail clippers for finer gauges.
You are to kind mate. I should give them a clean but I just use these for painting.
If I ever do attempt it please phone matron.
Thanks Mick, good to see you sticking with it.Comment
Damn, he's at it again folks..........That linkage looks real Bro!!! I really think you are having too much fun here and your scratchy work just gets better and better Paul..............
Knit one, Perl two. Knit one, Perl two. Knit one, Perl two..........Stupid scarf...........
AllenLife's to short to be a sheep...Comment
Jim, just waiting for the spark plugs mate
AllenComment
