Scotties big Zundapp
  • Mini Me
    • Jun 2018
    • 10711
    #61
    Don't think I will be trying this in 1-87 scale.......but thanks for the SBS.
    • scottie3158
      • 14201
      • Holbeach
      #62
      Originally posted by rtfoe
      Well worth all that time and thanks for the sbs Scottie.
      Richard aka Wabble
      Richard, no worries I hope it will be of use.
      Originally posted by therapy
      Thanks for this Scottie....
      Nick.
      Nick, my pleasure mate.
      Originally posted by Jim R
      Offset holes on the hub - I would have missed that. The kit spokes don't pass each other :rolling:
      Well done Scottie.
      Jim, Yes mate the moulded spokes don't show that.
      • scottie3158
        • 14201
        • Holbeach
        #63
        Rick, oh yeh of little faith lol.
        • Steven000
          • Aug 2018
          • 2826
          • Steven
          • Belgium
          #64
          Impressive Scottie :thumb2:
          • Neil Merryweather
            • Dec 2018
            • 5184
            • London
            #65
            Thanks for that Paul, it will be very useful if I ever get round to the BMW
            • JR
              • May 2015
              • 18273
              #66
              Brown sauce mind, not that 4BO condiment!!
              Excuse me Paul .
              Mr StuG will you stop maligning 4BO condiments please !!!!!
              • JR
                • May 2015
                • 18273
                #67
                Paul really shows your modelling skills .:thumb2:
                • grumpa
                  • Jan 2015
                  • 6142
                  #68
                  Beam me up Scottie......I love it!
                  Jim.
                  • boatman
                    • Nov 2018
                    • 14453
                    • christopher
                    • NORFOLK UK
                    #69
                    brilliant work Scottie on them spokes but marmite on a bacon sannie Ugh lol
                    chrisb
                    • adt70hk
                      • Sep 2019
                      • 10406
                      #70
                      To all who have liked and commented about the wheels thank you very much for the kind words. I thought I would do a SBS on the last wheel, just to show how I went about it and how easy it is. There are other methods but this one in this scale worked for me.
                      The first thing is to mark out where the spokes are and the angle they are fitted. Then remove a few at a time I normally do about four at a time this gives the hub plenty of support. Next clean up the seam line and remnants of the moulded nipples.
                      [ATTACH=CONFIG]n1189439[/ATTACH]
                      Using a drill bit the size of the nipple to be used, in my case some vinyl tube drill the outer rim using the marks as a guide.
                      [ATTACH=CONFIG]n1189440[/ATTACH]
                      Next using a drill the size of the spoke itself drill the hub. you will notice the holes on the hub are offset to allow the spokes to pass each other. The holes don't need to be deep as long as they provide a positive location.
                      [ATTACH=CONFIG]n1189441[/ATTACH]
                      [ATTACH=CONFIG]n1189442[/ATTACH]
                      The vinyl tube was cut at 7mm ish lengths and slid over the new spokes.
                      [ATTACH=CONFIG]n1189443[/ATTACH]
                      now push one end of the wire into the locating hole then slide the nipple down the wire into the hole in the rim until you have enough on the inside of the rim. when happy CA both ends in place.
                      Just remember to follow the correct direction of the spokes.
                      [ATTACH=CONFIG]n1189444[/ATTACH]
                      When happy snip off the remaining wire. Now repeat until you have worked round the whole wheel.
                      Sorry if it was long winded but hopefully you can see that all though time consuming it is quite easy if you take your time and get the holes in the right place.
                      cheers
                      Scottie
                      Now they really is rather good Scottie. Thanks for sharing.
                      • Mr Bowcat
                        SMF OG
                        • Dec 2016
                        • 4600
                        • Bob
                        • London
                        #71
                        Very nice work on the wheels Scott, might have to try that. It can't be any worse than applying CF decals to wheels.
                        Si vis pacem, para bellum.
                        • scottie3158
                          • 14201
                          • Holbeach
                          #72
                          Thanks mate Give it a go.
                          • scottie3158
                            • 14201
                            • Holbeach
                            #73
                            spent some time detailing the very basic pannier box hangers.
                            this is what the kit gives you.
                            this is what I came up with by adding the catch spring and a few other details.
                            and viewed from the other side. still needs a bit of tidying up.
                            cheers
                            Scottie
                              The main advantage of this scale is that it also becomes possible to add this kind of detail for mere mortals like the rest of us
                                • 18901
                                Wow, superb super detailing…..
