Scotties big Zundapp
  • scottie3158
    • 14201
    • Holbeach
    #76
    Originally posted by Jakko
    The main advantage of this scale is that it also becomes possible to add this kind of detail for mere mortals like the rest of us
    Thanks Jakko, at this scale it has to be done and it is a bit easier to do.
    Wow, superb super detailing…..
    Thank you Tim
      • 15687
      Great work Scottie.
      • scottie3158
        • 14201
        • Holbeach
        #78
        Originally posted by Jim R
        Great work Scottie.
        Thanks mate.
        • Mini Me
          • Jun 2018
          • 10711
          #79
          At this level of detail you might find yourself at the bench well into the New Year.....What a way to ring in the New Year!
          • Scratchbuilder
            • Jul 2022
            • 2689
            #80
            Scottie,
            Great work on the wire wheels, and on the pannier box hangers. Will draw up a chair and watch the progress on this old ESCI kit offering. (giving age away).
            • scottie3158
              • 14201
              • Holbeach
              #81
              Rick, That's the idea mate, it will stop me buying new kits :smiling:
              • scottie3158
                • 14201
                • Holbeach
                #82
                Scottie,
                Mike,
                More than welcome mate. I welcome any pointers along the way.
                • Lee Drennen
                  • 7711
                  #83
                  To all who have liked and commented about the wheels thank you very much for the kind words. I thought I would do a SBS on the last wheel, just to show how I went about it and how easy it is. There are other methods but this one in this scale worked for me.
                  The first thing is to mark out where the spokes are and the angle they are fitted. Then remove a few at a time I normally do about four at a time this gives the hub plenty of support. Next clean up the seam line and remnants of the moulded nipples.
                  [ATTACH=CONFIG]n1189439[/ATTACH]
                  Using a drill bit the size of the nipple to be used, in my case some vinyl tube drill the outer rim using the marks as a guide.
                  [ATTACH=CONFIG]n1189440[/ATTACH]
                  Next using a drill the size of the spoke itself drill the hub. you will notice the holes on the hub are offset to allow the spokes to pass each other. The holes don't need to be deep as long as they provide a positive location.
                  [ATTACH=CONFIG]n1189441[/ATTACH]
                  [ATTACH=CONFIG]n1189442[/ATTACH]
                  The vinyl tube was cut at 7mm ish lengths and slid over the new spokes.
                  [ATTACH=CONFIG]n1189443[/ATTACH]
                  now push one end of the wire into the locating hole then slide the nipple down the wire into the hole in the rim until you have enough on the inside of the rim. when happy CA both ends in place.
                  Just remember to follow the correct direction of the spokes.
                  [ATTACH=CONFIG]n1189444[/ATTACH]
                  When happy snip off the remaining wire. Now repeat until you have worked round the whole wheel.
                  Sorry if it was long winded but hopefully you can see that all though time consuming it is quite easy if you take your time and get the holes in the right place.
                  cheers
                  Scottie
                  Looks painful Scottie
                  • dalej2014
                    • Aug 2021
                    • 507
                    #84
                    Excellent stuff mate. I was blown away by the bikes you had at last year's show, and the SBS is graat.
                    On a humourous note, does this mean your model is now.... Wait for it... Bespoke!?
                    • scottie3158
                      • 14201
                      • Holbeach
                      #85
                      Luckily not to painful mate.
                      Dale thanks mate. I'll get your coat lol.
                      • scottie3158
                        • 14201
                        • Holbeach
                        #86
                        Well one pannier is done. Had a lot of fun adding the details. The hinge does work but ended up fixing the lid in place. The two catches had me scratching my head as to how to recreate them. they are the upteenth attempt and fabricated from 7 parts each not including the rivet detail. Although very far from perfect they are a 100% better than the kit offerings and I am happy with them.
ID:	1189752Click image for larger version
                        cheers
                        Scottie
                        • Allen Dewire
                          • 4741
                          • Allen
                          • Bamberg
                          #87
                          Great work Bro!!! I thought the spokes were cool, but this is really cool. Nice to see you having such a good time building this Paul!!!
                          Allen
                          • scottie3158
                            • 14201
                            • Holbeach
                            #88
                            Allen
                            Thanks Dude, I must admit I am having fun and it's a lot easier in this scale.
                            • Mickc1440
                              • 4775
                              #89
                              More great work Scottie, those catches are a work of art
                              • Neil Merryweather
                                • Dec 2018
                                • 5185
                                • London
                                #90
                                Beat me to it Mick - they are INSANE
