Scotties big Zundapp
  • Mark1
    • Apr 2021
    • 4156
    #121
    Scottie ,i got my mate Arthur on the phone, as your making such a lovely job on this he wants to know if he can take he's missus for a spin when your done!Click image for larger version
Name:	MV5BMDVhNzI2YjgtZWFlMS00NmM0LWJlOWEtZjgyN2Q2YjkyZmUxXkEyXkFqcGdeQXVyNjE3NjA1MzQ@._V1_.jpg
    • dalej2014
      • Aug 2021
      • 507
      #122
      Excellent stuff mate. Just excellent.
      • scottie3158
        • 14208
        • Holbeach
        #123
        Well Paul, with all this finery going on, this is going to a pretty long build. Well worth doing in the dark winter months. Great scratchy Bro and please give Neil a sandwich or something before he eats the jerrycans. I think he's hungry.............
        Allen
        Hi Dude, yes this one will take a while but enjoying myself at the moment. I better have a look to see what I can find for him to nibble on.
        Originally posted by outrunner
        Splendid work Scottie.
        Andy.
        Very kind of you Andy cheers.
        • scottie3158
          • 14208
          • Holbeach
          #124
          Originally posted by Mark1
          Scottie ,i got my mate Arthur on the phone, as your making such a lovely job on this he wants to know if he can take he's missus for a spin when your done![ATTACH=CONFIG]n1190105[/ATTACH]
          Ha ha that brings back some memories. I might have to stiffen the suspension a bit tho lol.
          Dale, Thanks mate appreciate the kind words.
          • scottie3158
            • 14208
            • Holbeach
            #125
            Not a lot of time at the bench, but I did replace the tie downs for the rain cover on the side car the original ones were to large both in size and wire gauge so I have redone them. I will post a picture later of the new ones which I think look a lot better.
            Work has continued on the side car chassis with some bolt detail added to the mud guard. The side lights had the gaskets added from thin sheet they are hard to see in the pictures. Finally the wiring to the lights was added. The cables were made by wrapping 2mm tamyia masking tape round some fine picture wire to represent the insulation with pewter cable clips.
            I need to tidy up the mud guard bracket.
            cheers
            Scottie
            • Mini Me
              • Jun 2018
              • 10711
              #126
              Very tidy. :thumb2:
              • JR
                • May 2015
                • 18273
                #127
                Hi Paul, very nice of Ben to make those cans for you. Typical of the guys on this site .
                Brilliant work as usual , in fact more impressive with each update .
                  • 15722
                  Better and better Scottie. Every improvement you make adds to the overall look.
                  • scottie3158
                    • 14208
                    • Holbeach
                    #129
                    Originally posted by Mini Me
                    Very tidy. :thumb2:
                    Thanks Rik, happy your looking in.
                    Thanks John, and you are so right a great bunch of people.
                    Thanks Jim, it is easier at this scale but by the same token more has to be added :smiling: :smiling:
                    • Mr Bowcat
                      SMF OG
                      • Dec 2016
                      • 4603
                      • Bob
                      • London
                      #130
                      Very nice as usual mate, particularly like the wire wrapping.
                      Si vis pacem, para bellum.
                      • scottie3158
                        • 14208
                        • Holbeach
                        #131
                        As mentioned earlier I have replaced the tie downs for the rain cover as the first ones were far to big and overscale.
                        I think you will agree they look a lot better.
                        Work has started on the engine. My references show slots cut into the top cover so thought I would have a go at replicating them. The oil pipe was replaced with wire and the filler nuts punched from plastic.
                        cheers
                        Scottie
                        The cover is just tacked on at the moment.
                        • scottie3158
                          • 14208
                          • Holbeach
                          #132
                          cheers Bob, it was a PITA to do but I think it adds some interest.
                          • JR
                            • May 2015
                            • 18273
                            #133
                            Paul I quite expect this engine to run, or is that asking a bit much :smiling2:
                            • scottie3158
                              • 14208
                              • Holbeach
                              #134
                              Paul I quite expect this engine to run, or is that asking a bit much ๏ฟผ
                              I trhink I may struggle with the float chamber on the carbs lol
                              • scottie3158
                                • 14208
                                • Holbeach
                                #135
                                My reference pictures show the gearbox as a separate casting but the engine moulding doesn't show it so I scribed in the joint and added the missing bolt details. Next the battery tray was fabricated from brass sheet and the clamp from copper wire and evergreen rod. Not 100% happy with the battery tray so I will probably redo it.
                                cheers
                                Scottie
