1/35 Meng 'Toyota Hi-lux' Libyan Technical pick up with ZPU-1 Anti Aircraft Cannon..
  • langy71
    • 1947
    • Chris
    • Nottingham
    So After my Israeli M6 build I was at a loss as to what to build next, maybe a little bit of burn out.....so upon sifting through the stash I spotted a quick mojo booster....the Meng Toyota pickup truck I bought a few months ago...so I set to work with what I thought would be nothing more than a quick mojo booster....famous last words an 'all....
    The Pickup is built, painted and partially weathered already, pictures to follow,
    so for now here's a few pics of the ZPU..
    (I may end up removing the bracket 'where the sight is fitted', I left it too close to a heat source whilst attempting to dry the paint, and it ended up warped)
  • The Smythe Meister
    • Jan 2019
    • 6248
    Interesting one Chris,
    I reckon that sight arm can be persuaded to get back into position with a dab of super glue eh?!
    I saw this kit a while back in my LHS and was sorely tempted,but as it's not really my genre I didn't take the plunge..... I look forward to seeing the whole thing
    • langy71
      • 1947
      • Chris
      • Nottingham
      I might have a go at straightening the bent bit Andy, although I have found a picture of an Israeli version of this cannon with no sight unit, hmmmmm,
      any how a few pics of the actual Pickup.
      Not sure about actually using the base it's on unless I can come up with a realistic way way to change it from a european farm wall to a more 'middle' eastern one..... watch this space... need to finish of a couple of things and then contemplate if I add a figure or two... or leave it as it is... hmmm decisions.. decisions!!
        • Jan 2019
        • 6248
        Very nice indeed Chris,
        A truly well used truck
        • langy71
          • 1947
          • Chris
          • Nottingham
          Anybody know what 'to victory' would look like in arabic? ... I've got the urge to freehand some arabic quotes on the sides to break up the overall flatness of the body.
          • Mickc1440
            • 4775
            That's seriously nice weathering Chris. really does look good.
            Use Google translate I just tried and the results will test your freehand
            • KarlW
              • Jul 2020
              • 1522
              Google translate may help.
                TBH, I would probably cut them off and replace them by plastic rod after this kind of damage.
                Like the others said, use Google Translate: إلى النصر. However, I would start by figuring out what slogans, if any, people actually painted on vehicles like these.
                • adt70hk
                  • Sep 2019
                  • 10400
                  That's brilliant!
                  • David Lovell
                    • 2186
                    WOW thanks for sharing ,people ask what inspires ,I always think if it makes me think wow then ive been inspired ,not to copy or build one just to bash on with what I'm doing thanks for showing. Dave
                    • eddiesolo
                      • Jul 2013
                      • 11193
                      Yes, yes, lovely work Chris! Superb detailing and weathering and the dio base sets it off beautifully. Top drawer stuff.
                      It brought back memories of the one I did in 1/16 RC, mine was a African countries rebal version, nowhere as good as yours.
                      • PaulTRose
                        • Jun 2013
                        • 6448
                        • Tattooine
                        you might not have to do it in arabic :smiling5:
                        i follow a motoring channel on youtube called vinwiki and funny enough this vid was on only this week
                        Per Ardua
                        • scottie3158
                          • 14197
                          • Holbeach
                          Chris cracking result mate.
                          • minitnkr
                            Charter Rabble member
                            • 7510
                            • Dayton, OH USA
                            Lovely work Chris. I'd mount the gun on a skid that can be bolted to the bed rather than depend on the gate. Untrained gunners likely use tracer and shell hits rather than open sights for guidance. Paint should do the trick on the base.
                            • langy71
                              • 1947
                              • Chris
                              • Nottingham
                              Any pics of said 'skid', i did think of building a base for the gun to sit on, but haven't given it much more than a passing thought..
