Scotties Pinky
Andy.Comment
Garry , I've found just the thing.
Off to get some knitting started, those tracks will be a lot easier .
Apologies Paul intruding scottie3158Comment
Attached FilesComment
Glad to see you binned the idea of binning your build, Paul. :thumb2:
For the future, if you really want to bin something you are building, I'll lend you my bin! :tongue-out3:
A well deserved Simon T scratchery award.
AndreaComment
Andrea, thank you your bin will be first on my list :smiling:Comment
Cheers Andrew they are quite easy to make.
Take a suitable length of correct diameter soldering wire. Fold around a suitable drill to give the curved end. Cut the shackle to the desired length. Using some smooth flat pliers crimp the ends so that they form the flats. Next file the flats so they are round. Carefully drill through the centres of each flat. Next take some wire the same diameter as the drilled holes, flatten one end in the same way as the flats on the shackle. Again radius the end. Drill a hole. Finally cut to length.
Ha ha Garry, there is no need to do that.
[ATTACH=CONFIG]n1198361[/ATTACH]
